Yokomo MR-4TC SD
Matt howard
I see a few posts back that you move the rear wish bone back to give more on power steering ,how dose this help with the handling of the car
Originally posted by ATLAS COPCO
Matt howard
Matt howard
SDW Question
TO ALL SDW Owners - Would it be possible to know what shock lengths you guys settled for, (both front and rear)? Also, did you resort to using droop? Thanks in advance.
Re: SDW Question
- jaybee
Thanks Jaybee. Haven't laid mine yet on the track too. . . . for fear of scratching the lower deck and titanium screws unnecessarily 62mm was just about right for my CGM and Black Special. But even this length now seems to be way too low for the SDW.
You think I can go for about 63 or 64mm without veering off from the way the car is supposed to handle with the stock setup?
JOELT
JOELT
joelt:
as long as the ride height and droop are correct, why would the shock length cause your car to dip more?
Hi Lee,
Ride height and some downward suspension travel are actually the problems I am anticipating right now with the recommended shock length of the SDW. At 60mm (or even 62mm), the resulting ride height might be a bit too low for our race track. I don't think I'll be able to hit 5.0 in front and 5.5 at the back with recommended shock positions (outermost hole for the arms). Also, the mentioned shock lengths do not give room for any downward suspension travel. The axles are about level when viewed from the back or front, with the shocks fully extended.
This is why I'm now asking around if increasing the shock length to about 64mm would cause me to veer off from the intended handling of the box setup.
JOELT
JOELT
droop problems, I see..
Well by all means extend the shock length. I don't think it'll affect the 'intended' handling characteristics.
If you want to maintain the shock length at 60mm, then you can cut/shorten the triangle/tube fixture inside the shock, where it straightens the shaft travel. Shorten both sides equally by about 2-3mm. I recommend cutting and then sanding to get a nice flat finish.
____ <- triangle
| | <- tube
shortened:
____
forgive the amateurish drawing, hope you understand it.
____ <- triangle
| | <- tube
shortened:
____
Thanks Lee for this tip!!! I never did think of modifying those triangular things we place inside the shock until now. . . . . The only thing I did was screw or unscrew the shock ends to get the desired length.
Btw, I understood your drawing perfectly. Thanks again.
JOELT
JOELT
Re: Re: SDW Question
Originally posted by JayBee
Haven't tried the car at all on the track, but I settled for 60mm all around being that this car was put together using Masami's world's set-up. I haven't talked to Steve W. from Speedtech, but heard from two reliable sources that when Steve took the car to the track a couple days ago, the car was HOOKED - box-stock! . But of course that doesn't mean squat for all tracks
- jaybee
- jaybee
I'll measure the length of hte shock on my car as soon as I get a chance. The first time out the car really surprised me, it was easy to drive and I nearly TQ that night. For those that know me, I usually never go well at SoCal (usually bottom of the A, top of the B type of finish for me) but for me to nearly TQ was unbelievable I went back out again this past Saturday, and only made some minor change to the car, and again by main time it was just like Tuesday again At this moment, I have to say, the car is a lot better than the driver behind the wheel (me!)
Steve Wang
Originally posted by Matt Howard
If you move the rear arms forward then you'll get more weight over the rear tires which will give you more rear traction (less steering). If you move the rear arms back then you'll have less weight on the rear tires and the rear suspension giving you more on power steering.
I understand now that you have explaned it for me
Steering Servo
Which steering servo are you guys using? I currently have an Airtronics 94737. It works well, but I'd like to use a servo that has similar characteristics, but smaller if possible.
Also, I'd like to see photos of your chassis' electronics layout?
Re: Steering Servo
- jaybee
Re: Steering Servo
not too fast until inducing oversteer, but just fast enough.
____ <- triangle
| | <- tube
shortened:
____
____ <- triangle
| | <- tube
shortened:
____
