Yokomo MR-4TC SD
#8642
Matt how would you take general twitchyness out of the CGM... and also what servo saver do you run. I have never broke any before but yesterday I broke 2, 1 associated and 1 stock yok one the long one....from the sd
#8643
SpeedTech's Spool
I've just intalled it in my SD but I wanted to be sure about how it should be shimmed.
I kept the 3 shims on the imput shaft and let 1 on the spool but it made an odd sound, so I removed the 1 on the spool and now it seems to be ok.
I'm just afraid to break gears, could someone confirm this??
Gilles
Gilles
#8644
ZS-010RTB=Rear Dogbone for Low-Friction Universals for Yokomo MR-4TC/TCSD Touring Car. Blue Anodized aluminum (1 each)
Would it be this dogbones...?
#8645
ZS-010RH Rear Hard Universal Driveshafts
The rear is a direct fit, but you need to grind down the ball on the front to fit on the front one-way like Matt said.
#8646
#8647
#8648
Re: SpeedTech's Spool
Gilles
Gilles
#8649
ZS-010FH Front Hard Universal Driveshafts
Will this work with just a regular diff, I don't us a spool or a one-way up front right now..
Do u grind down the end?
When u say grind down the ball how much do take off?
So u run the blues in the lightened blue dogbones in the back and in the front u use the Hard Universal Driveshafts...
Pics would help... if u having any...
#8650
#8651
#8652
Re: Re: SpeedTech's Spool
Originally posted by Matt Howard
Every gear box is going to vary ever so slightly in the shimming. I start by shimming my gears on the tight side and move shims until the gears feel like they're not binding up anymore.
Thanks,
With 3+1shims it wasn't working at all (grinding sound), now with only 3 on the imput shaft it seems to work ok, but perhaps I should put on the imput shaft on 1 on the spool, I'm just a little bit paranoïd about breaking gear rings
#8653
#8654
Get ahold of some of the hardened univerals for the old car. You have to shave down the end slightly to get them to fit but they're 100 times better than the stock cvd's. I don't remember the part # but I know that speedtech had them in stock awhile ago.
I remember the problems I had with the stock SD drive shafts. The CV joints had a nasty tendancy to bind and start friction welding themselves solid!! This would cause the 'wheel lifting problem' described.
When I happened to mention the fact that they either needed some 'fettling' work or replacing for alternative drive shafts, many people told me I was wrong and that the stock driveshaft were fine!!
Seems to me that seeing as the replacement HD universals require grinding anyway, doing a little work on the stock Constant Velocity type drive shafts isn't such a waste of time afterall Especially if you're prepared to do the corally/rc lab blade mod as well - it really helps smooth things out and reduces diff out wear rate too.
#8655
Originally posted by Horatio
This makes me laugh ;-D
