Yokomo MR-4TC SD
#7831
Re: question
Originally posted by eklips
will the harden universals front and rear for the mr4tc fit on the sd?
thanks
thanks
#7832
BTW, does anyone have the part # for the wide bumper? Too lazy to look for it in posts. . . . Thanks.
#7834
oooo nice timing i needed that too
#7835
Originally posted by Matt Howard
SD-001W, It should be out now, or at least on their way to hobby shops
#7836
wide bumper
Hi,
Got the wide bumper already. come with a plastic bumper piece and a larger foam bumper.
The trouble is... it is too big for some body shell. I can't install
it with Ride Stratus body. For Mazda 6, the plastic bumper piece
fit just at the front lower spoiler. The foam bumper is too big.
I suspect that it only works with the body shell is flat on the
front.
front.
#7837
Re: wide bumper
Originally posted by ongbenghui
Hi,
front.
Hi,
front.
#7838
TKG27
Here is the RPM Bumper modiication
1. Trim the 2 outer holes in the area that will touch the body mount pos, do it slowly.
#7839
TKG27
2. just trial fit the RPM bumper to the chassis until its snugly fit.
#7840
TKG27
dont worry about the RPM bumper being a little loose, once you sandwich it with the foam bumper it will not move, and the body mount posts and the mounting post for the upper bumper brace will prevent it from moving even in hard, head on hits.
bottom view
bottom view
#7841
TKG27
last one
notice the Body mount post and the mounting post for the upper bumper brace will prevent it moving side to side and front to back!
Trimming the area where the bumper might touch the front hinge pin holder is also a good idea.
#7842
#7843
Originally posted by daniz24
Picture of my SD SSG...
#7844
Originally posted by Techart27
Where did u get those graphite parts for the bumper and battery hold downs
#7845
The SSG bumper brace was from the old MR4-TC SSG Special I believe.
