Team Corally RDX Phi
#2566
#2567
Thanks for all the help guys! Should be getting my Phi hopefully by Wednesday.
Anyone know where I can get the diff spacer (part #COR75926) and a 1/4"x3/8" flanged bearing to modify the diffs? My local hobby shop doesnt have either part in stock. Looks like superiorhobbies.com is out of the diff spacer as well and the CorallyUSA website doesnt give you updates on what is in stock. Any help would be appreciated.
Chirag
Chirag
#2568
Chi we got them up here at timezone you just got to actually come up here and run... I know it 20 miles from Portland. will be up here all week at night getting ready for Vegas.
#2571
Paul
#2574
On the new diff do the conical washers go in with the cup up (v) against the nut or are they run opposing each other (v^)?
#2575
#2576
#2577
The 08 PHI Diff is 79680 and does not come with pulleys. The original 36T and 42T pulleys will still work.
We are out of stock on the new diffs for about 3 more weeks.
Jeff
#2578
After I get back from IIC i've decided to order a RDX Phi. Does the latest kit come with the new diff? Also what do I need, parts wise, thats not in the kit for running carpet with rubber tires? Thanks
#2579
Yo Jeff can u post on here when u guys get the new Diffs back in stock
I been wanted to get an pair of those
#2580
The only things I would get for the car are aluminum steering knuckles, 1.3 sway bar kit for front and rear, Black spring kit, Hard bumper, and 36T diff pullies if your going to be running brushless. You'll also need a shorter rear belt and bearing holders. It wouldnt hurt to pick up extra #35 F/R arms and some shims. The car is really good outta the box with a one-way, but with just a couple of key items its dialed.
