Team Losi JRXS Type-R
Order straight from PRS!
http://www.precisionracingsystems.com/
Their Pro Lite series fit right on the layshaft and come in 2 tooth increments.
Company Representative
Yes i use the 2 hole ones, but they also have 6 or 8 holes around the outside as well. I just use the 2 holes on the inside.
I use 111 and 115 from this page:
http://www.robinsonracing.com/catalog/64pitchspur.html
Why would you need 6 holes? more rotating mass. Actually I'm sourcing some short titanium screws and short aluminum screws so we can reduce rotating mass even further.
You really only need 2 screws.
just peace of mind thingie.
having lighter screws is good Idea thought, I already put those aluminium screws from PRS spur adaptor on my type- R
I ll go ahead and order the Robinson Derlin spur then
I currently use the RW's in 48 pitch. They can be brought in 1 tooth increments. This coupled with easy spur changes on the flyingfoxrc shaft makes it quick and easy to change your ratio to excatly what you want fast. I currently use 98-88spurs for 10.5-Mod.
I am going to go crazy and do some big flex modding for this weekends racing. I'll take some pictures and let you know how it all went. Now all I need is to find some time to sleep too!
I try to do all I can with my LHS, but I've eaten so many slightly out of round Kimbroughs I don't think about it any more. Robinson's are good though. they are machined and not cast.
yes the car needs a strong spur gear, I wish I can use a Losi Kevlar gears.
Hey guys,
I have just built up a new Type-R with the flying fox layshaft and spool (great products by the way) and am having some major dramas getting the chassis balance right.
I have 4 little digital pocket scales and am measuring the weight on each wheel. With the electronics and Lipo installed and no additional weight, the readings on the mini scales read something like:
Front left: 400g
Front right: 250g
Rear left: 220g
Rear right: 420g
I have tried moving the ESC and receiver around in all sorts of combinations without much effect on the weight distribution. Given that the servo and motor is immovable, there doesn't seem to be too much scope to get the balance right without going way over the 1425g limit.
I know I must be doing something wrong as I believe the balance of the Losi is pretty good. I have the shocks / droop / ride height equal for each side (but different for front and rear) so cannot for the life of me know what's going on. Overall the front/rear balance is generally about even and overall the left - right balance is about even, but the weight seems to be even on opposite corners of the car.
Can anyone help, or is this a general phenomenon with the Losi Type-R? Is anyone able to post a pic of a typical chassis layout that can best balance the chassis?
Thanks in advance,
Steve
Front left: 400g
Front right: 250g
Rear left: 220g
Rear right: 420g
Thanks in advance,
Steve
Hey Steve, judging from the way you worded the question, it sounds like you simply measured the ride height/droop and thought the corner weighting would be even from side to side. Despite your exacting measurements to set ride height and droop, the final adjustments to the spring perches need to be made on the scales or a tweak station (balance beam style). Even something as untweakable as the Type-R needs final adjustments to be measured this way, IMO.
Hey guys,
Front left: 400g
Front right: 250g
Rear left: 220g
Rear right: 420g
Thanks in advance,
Steve
Front left: 400g
Front right: 250g
Rear left: 220g
Rear right: 420g
Thanks in advance,
Steve
Your chassis is tweaked
this is how I straight em.
- remove all 4 wheels
- Losen all 8 top deck screws, remove Front screw on rear bulk head from the bottom.
- while lightly push down FR/RR shock tower, re-tighten all 8 top deck screws and put back bottom rear bulk head screws.
- loosen all 4 shock collars, tighten back down exact same amount left to rite.(make a mark on collar help) until collars barley touch the springs.
- do same for front and rear.
- check on a tweak station or a Scale
- Adjust Ride height
- re check the tweak. should be same.
Thanks guys. I'll try and un-tweak the chassis. I didn't realise tweak could have such a massive effect. I confess to not knowing much at all about chassis setup.
Thanks again,
Steve
Thanks again,
Steve
To check the scales are all working try measuring your corner weights then move the scales into different positions untill you have tried each scale under each of your 4 wheels. If you get different results then that proves the scales are not accurate.
I have a feeling that once you've run some quality machined spurs from RW or Robinson you will never want to run a molded spur again.
http://www.hpiracing.com/products/en/6996/
I have used these spur gears extensively in the past, and have always found them very reliable and durable due to the carbon content in them. If you are running softer aluminium pinions (the really cheap stuff), you'll find that the pinion will wear a bit quicker. Most of the 'racing' quality pinions will be ok with it. The spur gear takes a lot of effort to bend it out of shape, and mesh is good. Best thing is that I can now use it with the FlyingFox Layshafts!!!
Most kevlar/carbon spurs spurs from HPI start with the '69' part number. Only in 48dp in kevlar/carbon.
Teeth counts are 75, 78, 81, 84, 87, 90 and 93.
hope this helps someone...
Hey guys,
Front left: 400g
Front right: 250g
Rear left: 220g
Rear right: 420g
Thanks in advance,
Steve
Front left: 400g
Front right: 250g
Rear left: 220g
Rear right: 420g
Thanks in advance,
Steve
*Place all gear on you assembled chassis lightly held in place so it won't move around.
*Use two points or a round object up the center of the chassis (the center is marked with a small hole at each end) to balance on.
*Add weight on either the left or right to get it balancing right.
*Now get out your scales (at least 1kg) and a similar size solid object like a car stand. You will also need two objects to place the chassis on (I use my tools with a flat edge).
*Place the objects on the scales and base and adjust so the tools or what ever you use match the wheel base of your chassis.
*Now zero the scales and place the chassis on both objects making sure the axles are straight over the balance points (tools or whatever). Note the reading.
*Now switch the chassis around and repeat for the other end.
*You now have your front rear ratio so add weight to get it right. You can also move the weight you used for left to right balance forward or aft to help as long as it is the same distance from the center of the chassis.
Generally a balanced chassis is faster than unbalanced and light. The losi seems to like A 52/48% F/R balance.
Also here is a pic of the upper deck I just killed to try out tomorrow. I picked what parts to cut so I could also secure all the wiring neatly. I doubt there would be much in it anyway but the chassis is very flexy now.
Thanks again for the in depth explanations of tweak vs weight balance.
I will follow the advice given and sort the problems out prior to the cars' race debut this Wednesday.
Cheers,
Steve
Cheers,
Steve
On another topic my chassis is all back together with a cut up upper deck. I think I still need to put the front tray supports back in (cut down of course) to keep the battery still and am also looking at cutting the rear bulkheads up at the front so they clear the deck and don't rub when the chassis flex's. It looks like I have lost a massive 40g off the weight of the chassis though I also removed a bearing that the front belt ran over. It wouldn't take much more work and I could achieve a good f/r balance at a low weight limit like 1425.
