Team Losi JRXS Type-R
Company Representative
Hello,
Is it ok to mount my receiver and speedo on the top deck? Or would that be a really bad idea?
My motor cables arn't long enough to put the speedo at the front.
Why would it be bad for racing? I thought that keeping weight in the center of the car was a good idea?
Ill look into replacing the wires. If i do, the speedo will hang off the side of the chassis slightly, does that matter?
just about all the ESCs hang of the side, and it works fine. Mine has never came off.
he forgot a word "Low"
Low center gravity is it.
I got hacked on the side once, she hit me right spot and cost me $80 Rx, since she hit me, everything has been stood up.
Thanks for the info, looks like i need to buy some wire.
You could always get those SC10 side bumpers and put on you car. lol
Yeah, my receiver does not hang over but the ESC does slightly. I'm in the works and making a little carbon piece to go around in case of a impact. Cause even if I lay it side ways the fan hangs over.
LOSA3323 compatible with LOSA3327
does center pulley made for JRXS pro fits type-R?
Losi saying that white pullies (LOSA3323) are made for a Pro and black one (LOSA3327) is made for a Type-R
any one?
(I foud a white set in the box and wanted to install em on the flyingfox shaft once I get it, just to be look diffrent. )
any one?
any one?
any one?
any one?
any one?
I like the white ones so you can easily see power robbing carpet/foam balls of gunk that get stuck in the pullies. However the black ones look nicer longer since it does hide the grit and dirt.
My set up? I was going to try Lucas's set up in Xray race. I just need a jig saw. to chop it up.
if I can't get a saw then I wll just run my usual, i uploaded it on my blog for you.
