Team Losi JRXS Type-R
#9241
Hi guys,
I recently bought and built up a Type R to race here in Australia. I haven't actually raced it yet as I'm going to try it out in 17.5T brushless stock (I tried a 10.5T brushless not having driven one before and found it too quick for my skill level just now). I have a couple of questions if I may:
(1) Can you buy the 4 degree C hubs just in pairs without the steering knuckles?
(2) Is the car considered to be generally pretty robust? In my couple of testing outings with the 10.5, clipped the boards pretty lightly and broke a suspension arm and a c-hub on separate occasions.
(3) Are there any aftermarket parts that are stronger than the kit parts? (like the aforementioned arms and c-hubs)
Thanks in advance,
Steve
Thanks in advance,
Steve
2.The car is not that bad unless you tend to hit a lot of boards. There were a bad batch of A arms when the car first came out, but I would think they are gone by now. I use the Graphite C hubs as well as the rear hubs. They are from the original XXXS/JRXS. They seem to hold up alot better for me.
3.Aftermarket as in Aluminum? You don't want that for it will just end up tearing up something else on the car. Work on your driving and you won't be replacing said parts as often.
#9242
Hi guys,
Thanks in advance,
Steve
Thanks in advance,
Steve
The hubs and spindles come together but you can buy aftermarket alloy seprately.
I have only had the chassis for a limited time so far but it does seem to be quite strong. The EA3 material that the type R suspension is made of is very strong but brittle. It will take most hits well but everything brakes when you hit stuff eventually.
Where bouts in oz you race?
#9243
Thanks guys for the rapid responses.
I take it on board that upgrading to aluminium hubs will only transfer the breakage to another (and more expensive) component. I understand these parts are sacrificial but in 2 brief outings with the 10.5T, only lightly hit the boards causing the breakage.
I have bought the PRS adaptor to change the FDR...is about 3.5-3.6 about right?
Dragonfire...I race in Boronia in Melbourne weekly on Wednesday nights. Great club atmosphere and the track layout is changed each week, but unfortunately is defined by boards which takes it's toll. Having said that, I was racing a TA05 and TB03 in 540 pro...didn't hit the wall much but when I did, some hits were quite hard and only broke a c-hub once in quite a few races.
Thanks again guys...gotta work on my driving!
Steve
Steve
#9244
i'd really take a good look at this ride for nats in oct this yr since its takin place in my backyard. but can some1 point me to the correct # for the 1way unit and who actually has 1. all i hear is that no1 can get a 1way for the car.
thx
R
thx
R
#9246
1st make sure you have the PRS spur adaptor as you will need it for 17.5 gearing.
#9247
#9248
There is a guy here in oz designing a replacment layshaft that has a normal spur adaptor on the end. This will solve both the spur gear problem and the lipo/pulley problem in one hit plus be 1/2 the weight of the stockl layshaft. Hoping he gets the new proto type done this week and I'll post a pic when I have it.
#9249
Working on a 4mm prototype right now for you Dragonfire.
Also in regards to 6deg caster. Been runnung 6deg for a few weeks at Windsor. The car seemed to maintain great turn in and be a little more stable on power out of tight turns where power oversteer used to trouble me.
The Losi setup guide say's more off and less on power steering with more caster which is about what I experienced. I always thought it was the other way around with other cars??
#9250
Thanks dragonforce and jaz, you guys were right on. Both diff springs were the wrong ones. Black and too long. Again, thanks for the help guys.
#9251
Thanks guys for the info on the spur gear adaptor, i will be getting one of those really soon.
#9252
Can you believe that S%@T! C'mon Losi... Stop giving your packaging team free JB to drink during working hours! 2 kits both with incorrect or missing parts, BOTH spools with 41 pulleys instesad of 42's!
Time for some offensive e-mails
Yes mums tablecloth is great. The camera didn't like my white setup board so this actually worked good. Weights are on as well now minus 10g but have 20g on front bumper and around 90g on left front. Currently on 51/49% f/r. Would have liked more over the front.
Pull off the flat ring from the 41 T pulley and put it in the 42 T pulley
ciao ciao
#9253
Hey guys,
Here's some pics of the pullies that i had lathed/turned down to clear some LiPos. I took about 1.2-1.5mm off each face (arrowed in red). There is a pic with the pullies assembled, and you can see the amount of clearance gained.
Looking at the pic with the pullies on the layshaft, if there are concerns about the drive pin for the front drive pulley slipping out, you can always slip an appropriately sized O ring over the drive pulley to stop that from happening.
Last 2 pics are of the wiring layout that I use with the wires along the side of the chassis. I use 3M 'Command' Decorating Clips (part number 17026) to hold the wire down with cable ties.
Hope this helps a few...
#9254
Hey guys,
Attachment 424302
Attachment 424303
Attachment 424304
Attachment 424305
Attachment 424306
Attachment 424302
Attachment 424303
Attachment 424304
Attachment 424305
Attachment 424306
#9255
How much weight do you guys run? I've got about 160g...
