Team Losi JRXS Type-R
#8236
Here
http://www.precisionracingsystems.com/products/18
I use one with a 104 spur and somewhere between a 52 and 48 pinion to reach a FDR of 3.66-4.0 (17.5 motor, rubber tire)
#8244
Just curious?
Here
Just curious? How does this adapter facilitate the smaller spur gears? ie Why wouldn't a 108 or 104 fit the car as is? PM would be preferred to save time but I'm flexible.
#8245
The smallest spur Losi makes is 118 and the adapter allows you to use after market smaller spurs then what Losi makes. The after market spurs have a bigger hole in the center and will not attach like the Losi spurs do.
#8246
With the PRS adapter I actually went down to a 108 and using a pinion in the 40's for my brushless set up. Works real good.
#8247
What should I be running for gearing with a 10.5 and rubber tires?
#8248
Location: Colorado, USA, The land of the free and the home of the brave!
With a 17.5 my fdr is about 4.5 which is perfect for my track, so 5 is about right....
#8250
Anyone wanna see why losi is ahead of their time. XRay just basically copied the lcds exactly, 4 years after there were patented. The only difference is the set screws instead of the shrink wrap. And personally I like the shrink wrap better. I have never had shrink wrap come loose and back out like a setscrew. Im just waiting for the 009 type r next. First it was the Eight now the LCDs. Losi must be doing something right.
http://www.teamxray.com/teamxray/new...863c1d9fb4aaba
