Team Losi JRXS Type-R
#7816
Not getting into a Nimh/Lipo debate. I have my steel trays sitting here for when the enevitable happens. I just don't believe in hacking the car up to get a battery to fit when I am sure there are ones that will just slide right in. I think there needs to be some sort of standardization on the packaging of Lipos so you don't have these issues. I was going to do Lipo for IIC and friends were willing to let me borrow their brand new Orion 3600 packs, but they don't fit and I am not modding the car to get them to either. I don't feel you should have to.
there is no need to hack up the car or the battery to make one fit the other.
I say just buy one that fits
#7817
#7819
Using that mentality you shouldn't have to true tires either. The car was designed for lipo before any other, it fits most, but some have found that they can cram a better battery into a little more space, the cars just need to catch up. If you're really that lazy to dremel 2 pieces of plastic and a couple shims, there are plenty of xrays sitting on a shelf waiting for you.
#7820
#7821
I have the Trakpower 4900...and i had to use the dremel, just a little, but needed.
I believe the car was designed around the Orion Platinum 4800.
The ideia of dremeling the pulleys is good to try the A123 cells. I will have a better look again, as I noticed the space between the pulleys was short for them
#7822
Since i've gotten a little better at driving and hit things less i've found that the type-r is just my speed!! It doesn't need much care and feeding and is perfect for the lazy racer!!
#7824
I don't see how truing tires relates to a battery not fitting in the car. I am not lazy, just no point in weakening the car to get a battery to fit when there are better options. I will never own an Xray. I don't need a new car every 7 months. My point was that the Nimhs increased in volume but the cells them selves were not that much different in size. What I am saying is there needs to be a standardization on the pack size for Lipos so you are not hacking the car to make them fit. If you want to hack your car to make them fit, then by all means do that. I will research what will fit with no modification and then buy. Structual integrity will not be an issue then since I will not have to mod anything to get the pack to fit.
There is now a ROAR standard, it was just released after the type-r was designed, Losi can EASILY make a slightly wider spaced layshaft and bulkheads with a bit more clearance if they wanted too, but since their focus on onroad seems to be less than desired these days I don't see that happening.
#7826
#7827
#7828
Location: Colorado, USA, The land of the free and the home of the brave!
