Team Losi JRXS Type-R >
Like Tree52Likes
Old 07-06-2007, 10:27 AM
  #4816
GCracker's Avatar
Yes to the D rings, No lube, yes to the thrust bearing (with grease) just pull your diff pulley wipe all the lube off assemble tight and presto all done
GCracker is offline
Old 07-06-2007, 10:42 AM
  #4817
Yeti35's Avatar
Originally Posted by hobbipro
Just received my 42t spool in the mail today. I was surprused to see no directions. The manual is no help either, My question is do you leave the D-rings on and just swap out the pully itself, what about the shim?
The shim you refer to is actually a form of a slipper and if you noticed you only have one true D ring. The other one does not have a notch in it. Just clean the grease off the rings and put the spool pulley on and make it tight. Not so much that you strip the threaded outdrive out, there has to be some give to it.
Yeti35 is offline
Old 07-06-2007, 12:46 PM
  #4818
hobbipro's Avatar
Trader Rating: 23 (100%+)
Works like a charm. I know there's only 1 D-ring, Easier to explain it that way, plus helps out if people are reading, most understand what a D-ring is.
hobbipro is offline
Old 07-06-2007, 02:46 PM
  #4819
POOKYT's Avatar
D-ring goes on D-outdrive and is held together by d-screw. LMAO Sorry just had to do it.
Brant
POOKYT is offline
Old 07-06-2007, 05:17 PM
  #4820
STLNLST's Avatar
Trader Rating: 32 (100%+)
I'm going into battle tomorrow for the last club race before the nats. Gotta see if my set up works at this track. If it does....then I'm dialed because this is where I'm racing for the remainder of the summer.
STLNLST is offline
Old 07-06-2007, 06:04 PM
  #4821
POOKYT's Avatar
Go get'm Clint!
Brant
POOKYT is offline
Old 07-06-2007, 09:38 PM
  #4822
STLNLST's Avatar
Originally Posted by POOKYT
Go get'm Clint!
Brant
Thanks bro. My buddies are racing at the nats track right now and they told me it's very high bite and tight as hell. Even though the layout will be changing for the nats the high bite is something that we aren't really use to. The normal set up's don't seem to be working for my boys right now (maybe they should have bought a Losi) I'm hoping that the thicker chassis the Losi has helps with the high bite.
STLNLST is offline
Old 07-06-2007, 09:39 PM
  #4823
STLNLST's Avatar
just had to see if I could quote myself.....LOL
STLNLST is offline
Old 07-06-2007, 10:11 PM
  #4824
RussB's Avatar
oh man, i raced stock tonight for the first time in a few years. picked up a new 13.5 pro and geared it to the moon. my car worked awesome, and qualified 3rd on pace with some of the fastest stock guys in the area. the main i did ok, lets just say i was "stress testing" the new a-arms... but i finished and not too far off 3rd.
between the new arms and my hybrid xxxs/cyclone cvd's front and rear, the car was absolutely bulletproof.
RussB is offline
Old 07-07-2007, 01:04 AM
  #4825
GCracker's Avatar
Default Marcos please e-mail me the editable setup sheet
Ok here goes my stock setup when Marcos e-mail me the editable setup sheet I will repost but this is a very tractable setup same order as setup sheet
Toe 0.5' in
Ride Height 5mm
Camber -2
Kick anti dive n/a
Caster 4
Droop 3mm over ride height
Front pivot 0'
Roll center High
Arm spacing middle
shock position 3
Steering Rack 2
Ackerman 1
Camber link 3
Camber ball stud std
Sway bar .40
Arm length long
Front Spool
Pulley 42T
Diff height High
Axle LCD
Hex width .165
Oil 40
Piston 56
Spring 20
Bladder Black
JR Link High
1x1mm washer under spindle ball stud
Rear Toe 2'
Ride Height 5mm
Droop 3.5mm over ride height
Camber -2
Anti Pro Squat n/a
Hub std
Rear pivot 1'
Roll center Low
Arm spacing Long
shock position 3 outside
Camber link 8/A
Sway bar .30
Arm Legnth Long
Diff height Low
Axle RCD
Hex width .195
Oil 35
Piston 56
Spring 15
Bladder Black
1x1mm washer under camber link ball stud
CO27 F Brush purple/red springs 128T/37T
Traction compound Tire Tweak baked in at 80C for 20 mins
Thanks to Schreff for setup ideas....
This was one of only 3 cars that ran 9.7-10.0 laps all night
GCracker is offline
Old 07-07-2007, 05:16 AM
  #4826
STLNLST's Avatar
Toe 0.5' in
Ride Height 5mm
Camber -2
Kick anti dive n/a
Caster 4
Front pivot 0'
Roll center High
Arm spacing middle
shock position 3
Steering Rack 2
Ackerman 1
Camber link 3
Sway bar .40
Arm length long
Front Spool
Pulley 42T
Diff height High
Axle LCD
Hex width .165
Oil 40
Piston 56
Spring 20
Bladder Black
JR Link High
Rear Toe 2'
Ride Height 5mm
Camber -2
Anti Pro Squat n/a
Hub std
Rear pivot 1'
Roll center Low
Arm spacing Long
Camber link 8/A
Sway bar .30
Arm Legnth Long
Diff height Low
Axle RCD
Hex width .195
Oil 35
Piston 56
Spring 15
Bladder Black
www.gearchart.com for the editable sheet.
STLNLST is offline
Old 07-07-2007, 07:19 AM
  #4827
GCracker's Avatar
cant save the form can only print from gear chart. no printer
GCracker is offline
Old 07-07-2007, 08:06 AM
  #4828
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
pm me your email and i will email you the set up sheet
Marcos.J is offline
Old 07-07-2007, 06:58 PM
  #4829
GCracker's Avatar
ygpm
GCracker is offline
Old 07-07-2007, 09:55 PM
  #4830
Super Moderator
Marcos.J's Avatar
ygpm
its on its way to you
Marcos.J is offline
