Team Losi JRXS Type-R
#4743
#4744
Super Moderator
try the set up posted on www.gearchart.com Also with Marcos set up if you want a hair bit more steering you can leave everything the same but go to the standard camber link in the front. That seemed to give me a bit more steering
good luck at the nats
#4745
will going to the jr link in the "high" position not add some of the same affect.. i don't mind the jr-link's non adjustability since it is very durable and seems to eliminate a lot of slop (i would like to capture all the ball cups though).. also the jr-link can be shimmed up too right? i have a set of perfect circle shims for my pancar for minute adjustments that look like the ticket for between the lower washer and the link.. i dunno. i now have 5 runs with the car..
#4746
Where is that setup again? I went back a few pages and did not find it? I knew I should have made a copy of it when I saw it.
#4749
#4750
For set-ups regarding JRX-S & JRX-S Type R
If you own some other car, here you will find what will suit you in term of set-up
#4751
That's why I'm here.....to test everything so that when racers have questions they also get answers If the nats track is very high bite I might try the "jr" link again but I think the standard link will be just fine.
TALLY RC- I ran the "jr" link in that position at the reedy race and it was pretty good. In fact....that's Todd's favorite position for the front camber link.
#4755
Camber Links....
Are any of you guys having issues with the camber links, both front and rear, staying on? It seems any time that I brush the pipes that mine pop off from the chasis. I have changed them out several times and continue to have this problem.
I know the short answer is to stay off the pipes so you can save that one
Are you guys cuttng done the threads on the axels?
