Team Losi JRXS Type-R
#3994
is any one can help me, I have a diff problem during the race yesterday, both of them (f/r) are burned at the spool which has a ball bearing in it (the plastic part is melt). I use Novak GTB with 4.5 brushless motor at 9.56 final ratio.
#3995
SoCal Rookie needs FR A Arms
Picked up my JRX-S Type R Thursday was racing Sat at HB .Im trying to locate some from A arms, everywhere i try is out of stock can someone plz help ive tried all the usual sources, sppedtech, losiparts, horizon, ultimate hobbies etc
#3996
Super Moderator
#3997
#3998
Sounds like both of your diffs were too loose and slipping during acceleration. Heat from the friction of the diff balls and rings melted your pulleys (even though you said 'spool', I assume you mean 'pulley'?).
#3999
Originally Posted by STLNLST
I too will be going with the short arms. The shorter one's seem to hold up a little better compared to the longer one's from what I've seen at my local track.
#4000
For anyone who is still running carpet this time of the year, you may want to give this setup a try...i ran it at Speedzone in CT (tight track with good traction) this past weekend for one of their trophy events...my car was really fast, but may be a bit aggressive depending on your tastes...it steers like crazy both in and out of the corner.
#4001
#4002
Asphalt setup up for short arms anyone?
Originally Posted by Marcos.J
pretty much everybody is out of stock but you can find the short arms still, you can use them , i actually put them on my car to try out and the car worked alot better for me.
Thnx
#4003
5 Cell battery tray needed
Hi guys, any one else had problems when running 5 cell packs.
I have run 5 cell for a while now, with them in the rear position.
In the pictures below you can see the problem, there is nothing to keep the cells from moving forward in a crash.
so i really do believe a 5 cell battery tray is needed.
Ps, my cells used to be glued together
cheers
Tim
cheers
Tim
#4005
You can get a piece of plastic pipe from a hardware store that is the same diameter to take the place of a cell.
