Team Losi JRXS Type-R >
Like Tree52Likes
Old 05-02-2007, 04:42 PM
  #3661
Mike Haynes's Avatar
Originally Posted by syndr0me
Cool, thanks, I'll give it a shot! How tall are you guys starting those pro 53s for club racing?
I usually start at 58mm.
Mike Haynes is offline
Old 05-02-2007, 06:48 PM
  #3662
Trader Rating: 264 (100%+)
How much rebound are you guys getting when you build your shocks?
Also how many o-rings in the bottom of the shock?
Fred Perkins is offline
Old 05-02-2007, 06:51 PM
  #3663
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
it has 1 o-ring but but it gives you the option of using 2
Marcos.J is offline
Old 05-02-2007, 06:53 PM
  #3664
I know that!
I was just wondering what the general consensus on the 1 or 2 orings.
Old 05-02-2007, 06:58 PM
  #3665
Super Moderator
Marcos.J's Avatar
I know that!
Marcos.J is offline
Old 05-02-2007, 07:18 PM
  #3666
Smart a$$
Old 05-02-2007, 07:28 PM
  #3667
schreff's Avatar
Fred,
I believe most people, including team guys, are using 1 o-ring on the bottom. That's what most every other manufacturer does anyway. I, personally, don't see any type of performance advantage to running a double o-ring seal.
As far as rebound... that depends if you have anything above the bladder or not. I know with the shock built normally with the black bladder, you could get next to zero rebound if you wanted. On my shocks with the Tamiya Red foam in, the rebound is decently fast and about 50% of the shock extension. I'm not really sure if I like it or not. It all depends on how you bleed them as well.
schreff is offline
Old 05-02-2007, 07:48 PM
  #3668
Trader Rating: 90 (100%+)
1 o-ring here as well. I tend to build my shocks with as little rebound as possible. I like the shock to work more as a damper and not a spring. All comes down to personal preference and what is working best with the particular set up..
RBLove is offline
Old 05-02-2007, 07:59 PM
  #3669
Always used 1 oring to date...
I usually run a little rebound up front and none in the back.
Old 05-02-2007, 08:07 PM
  #3670
POOKYT's Avatar
1 O-ring on lower seal. And usually 2 O-rings on top of bladder. I like a lot of rebound on the asphalt.
Brant
POOKYT is offline
Old 05-02-2007, 08:11 PM
  #3671
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
If the track was smooth wouldn't you want more of a rebound? Whereas, if the track was bumpier you would want less rebound so it didn't look like a pogo stick going around the track?
Kraig is offline
Old 05-02-2007, 08:43 PM
  #3672
POOKYT's Avatar
I agree.
Brant
POOKYT is offline
Old 05-02-2007, 08:54 PM
  #3673
RussB's Avatar
o-rings above the bladder? i've always run just the white bladders.
RussB is offline
Old 05-02-2007, 11:51 PM
  #3674
highwayman's Avatar
how does the 2white orings compare with the red tamiya foams?
highwayman is offline
Old 05-03-2007, 04:41 AM
  #3675
POOKYT's Avatar
Originally Posted by highwayman
ho
s?
2 o-rings will give you more rebound.
Brant
POOKYT is offline
