Like Tree780Likes
MTC3
Old 06-10-2025 | 06:44 AM
  #316
disaster999's Avatar
Regional Moderator
Originally Posted by Mig89
How's the weight now it? For me that was a performance issue in the stock racing and using bigger batteries.
Originally Posted by Dan
What weight batteries were you using? I had to add some weight to my MTC2 when I had mines.
As it sits right now with wheels the chassis weighs 1143g with a 230g ULCG battery. With ~100g body + body clips its still pretty light at under 1250g which I would still need to add ~40g of ballast to meet 1280g minimum for my club races. With a bigger 22.5mm tall battery, which is usually around 270-280g, I should be just above the weight limit.
disaster999 is offline
Old 06-10-2025 | 09:03 AM
  #317
around 270ish. once I switched to ul bodies I had about 20gr to play with. No center 18gr weight either but I did have the esc plate. I also had to space out my motor to help the left to right balance along with being mindful where the esc was placed. IDK that is just my experience I was always around 1330-1335. If I needed to shift the weight balance fwd, I was always in the 1340 range, depending how much I needed to calm the car down.
I'm sure if I would've used more of the lighter parts, caster and toe plates, weight wouldn't have been an issue for me.
Mig89 is offline
Old 06-10-2025 | 10:40 AM
  #318
h2e's Avatar
h2e
If it's possible to give just the empty chassis weight w/o electronics, it's just easiest for everyone to read...
gigaplex likes this.
h2e is offline
Old 06-10-2025 | 04:14 PM
  #319
gigaplex's Avatar
For some points of comparison, my SP1 was 467g, MTC2R was 471g, X4 24 was 508g, and AT1 was 587g. The MTC2R was already pretty light.
gigaplex is offline
Old 06-10-2025 | 10:44 PM
  #320
Regional Moderator
Not at this moment when all my electronics are installed, lets see if theres anyone that could measure the empty chassis when they are done building theirs.
Old 06-14-2025 | 07:32 AM
  #321
Anywhere to get parts for the kit yet?
bertrandsv87 likes this.
Antimullet is offline
Old 06-14-2025 | 10:40 AM
  #322
Maybe this is way some people buy two kits
Under Dark is offline
Old 06-14-2025 | 12:38 PM
  #323
Team EAM
We are slowly starting to get some parts in this coming week I believe.
EA
Francis M. and Antimullet like this.
EAMotorsports is offline
Old 06-18-2025 | 09:02 AM
  #324
Is there a comparsion chart for xray springs?
Gero is offline
Old 06-18-2025 | 12:07 PM
  #325
Whatever car you buy it has to be two kits and lots of hubs, arms, and hardware...
bertrandsv87 is offline
Old 06-19-2025 | 06:40 AM
  #326
Marcos.J's Avatar
Super Moderator
if they drive like you lol
racenut123 and OVA like this.
Marcos.J is offline
Old 06-19-2025 | 08:03 AM
  #327
Team EAM
Xray springs will not fit the car. Only Mugen springs fit it.
EA
dawgmeat and NutDriver like this.
Old 06-20-2025 | 08:34 AM
  #328
Car is really nice, all the rod ends thread in nicely - no need to run them on a drill to break them in, just a bit of chapstick and good. Some really cool features on this chassis. Nice to see specs on body mounting in the manual- made it easy.
Racing this weekend on a semi bumpy, medium grip asphalt track, really interested to see how she performs.
NutDriver and oldernoob like this.
Old 06-20-2025 | 12:04 PM
  #329
oldernoob's Avatar
Halfway through building mine. Very interested to see how the thin chassis copes with low grip tarmac/asphalt.
STLNLST likes this.
oldernoob is offline
Old 06-20-2025 | 02:18 PM
  #330
Yea I don’t want to find out. I’m going to use some UMHW thin tape to see if that helps and I’ll be tweaking the upstops to see how it goes.
oldernoob likes this.
