Like Tree780Likes
MTC3
Old 06-24-2025 | 01:54 PM
  #346
Originally Posted by rcfiend
Quick question, did a search and couldn't find anything. Are there any carry over parts from the previous car, such as, sway bars, arms, chassis weights, etc? Thanks in advance!
drivetrain parts mainly. battery weights are different if I remember correctly. The diff is the same incase you had extras.
Mig89 is offline
Old 06-24-2025 | 02:40 PM
  #347
rcfiend's Avatar
Cool. Thx.
rcfiend is offline
Old 06-24-2025 | 02:55 PM
  #348
Not a lot of parts crossover from the old kit. This is a good video on the MTC3.
Antimullet is offline
Old 06-24-2025 | 06:05 PM
  #349
Team EAM
The driveshaft and diff is the same as the R...Not the original MTC2 just fwiw
EA
Antimullet likes this.
EAMotorsports is offline
Old 06-24-2025 | 06:33 PM
  #350
rcfiend's Avatar
https://youtu.be/GuXFDS33yyQ?si=rpsHng5_V-Rmksoi
Thanks!
rcfiend is offline
  #351
rcfiend's Avatar
EA
Thanks EA!
rcfiend is offline
Old 06-24-2025 | 07:36 PM
  #352
Team EAM
Thanks EA!
Also the shorty battery weights are the same but the normal battery hooks for long packs are not.
EA
Old 06-24-2025 | 08:12 PM
  #353
rcfiend's Avatar
EA
Cool, good to know.
rcfiend is offline
Old 06-25-2025 | 08:48 AM
  #354
Team EAM
Kits didnt last long....came and gone in about an hour.
EA
NutDriver likes this.
Old 06-25-2025 | 04:32 PM
  #355
jag88's Avatar
EA
Did you save one for yourself?😉
STLNLST likes this.
jag88 is offline
Old 06-25-2025 | 09:44 PM
  #356
TonysScrews's Avatar
Been a Mugen dealer for 20+ years now. Took a break from racing off-road for a while, but now that I'm back racing again and running on-road, we will have the MTC3 kits, parts and option parts in stock soon.
hunterdawg likes this.
TonysScrews is offline
Old 06-26-2025 | 01:15 AM
  #357
Svendc's Avatar
The new car looks amazing and i'm a fan of mugen TC's but when i look @ the setupsheets, it looks very strange to setup, not like a typical setupsheet, i don,t understand the logic, that's the only thing i'm not pulled the trigger to buy this car.
Svendc is offline
Old 06-26-2025 | 01:46 AM
  #358
gigaplex's Avatar
What parts looks strange?
gigaplex is offline
Old 06-26-2025 | 02:30 AM
  #359
Has anyone noticed that you can't remove the bumper easily as it goes up through the front arm. Seems an odd choice, I remove mine for cleaning, roll centre adjustment etc.
Also, I've noticed that on the setup sheets, they run higher roll centres. Does anyine know if the A2173f and rear version will be coming in different thicknesses
Grindog001 is offline
Old 06-26-2025 | 01:16 PM
  #360
Yeah i also found the layout of theses setup sheets a bit cluttered and overwhelming at first. But with nearly everything, when you look at it twice and you know what you are looking for it becomes second nature.
As far as i know there are currently no different parts to A2173F/A2173R. But increasing the rollcenter is no problem, just put additional shims between the part and the ball and use a longer screw if necessary.
It would be interesting when going lower RollCenter than the tickness of A2173F/A2173R. I didn't measure it while building but my guess would be it is 1.5 mm or 2.0 mm thick. These distances of the ball above the chassis seem to be what nearly every TC is using.
(Not factoring in the geometry of the pivoball itself, some have different necks under the actual "ball")
I havent seen a setup sheet for current TC Platforms that use lower Rollcenter Shims under the arms for a long time. Only if it was a "experimental" setup because of strange conditions or tires which required strange measures.
And most of the times these setups weren't super useful, because of these strange conditions. Or the guys uploading it weren't happy with it either but was their last setup iteration.
Grindog001 likes this.
Tomillia is offline
