CK25AR 1/12th car kit from Team CRC
#406
anyone tried or seen this newer chassis?
https://teamcrc.com/product/33576-2-5mm-carbon-fiber-chassis-ck25-ar2/
Any idea what the AR2 would mean?
#411
Quick question... the ride height on my car is good and the car handles decently, but my chassis seems to be dragging the track at the back near the rear pod. Do I need to adjust droop or add more preload on my center spring? This is my first trailing link car and I'm not sure how much rear droop this car should/can have.
#412
#413
It's not abnormal for that to happen, when the car corners it compresses the center pivot quite a bit. If it gets bad it can cause weird handling, so the best thing is to put a bump stop on the shock. I make mine from a piece of silicone tubing and a countersunk washer.
#414
The only trick is that in order to put the spring retainer on you need to put it on the shock end first and then thread it onto the shaft.
If the bump stop tubing piece is too long you can cut it shorter with a hobby knife. I set mine so I get the bump stop action just a millimeter or so from bottoming out the chassis.
#415
Been using bump stops for years, but I use the shock o-rings instead of tubing.
#416
CRC’s new CK25AR2 chassis plate option accommodates inline battery placement nicely. Mine even came with 2 red alloy standoffs and the little graphite cross piece that carries the front of the center shock and positions the battery. For those who prefer a transverse lipo, that works too, simply by using the standard post for attaching the front of the shock. Either way, it’s quite a nice setup.
#417
Thank you for the clarification!
#418
#420
IMO the 730 limit is outdated and should probably be adjusted down to around 700 or so to reflect the fact that today’s electronic are smaller and lighter than in years past. Piling on a lot of useless ballast in order to meet an outdated weight minimum only slows the cars, works the motors harder, and wears out the tires faster.
