Team Associated TC5
#9376
Just seen your piscture there and it looks to me like you have the right side in the high hole and the left side in the low hole on the bulkhead easy mistake to make :P
#9377
I am using a lipo weight but the issue is on the bat. side of the car. I have a couple of dig. food scales I will use to measure left and right side weight. Her is a pic of what the rear shocks look like
Attachment 444431
Attachment 444431
if thats not it then you may have mismatched the arm mounts or the arm mount holes on the bulk is not the same from left and right.
OR you are not setting your ride height with the battery attached? but that would be a left spring too compressed issue
#9378
Attachment 444431
Attachment 444431
#9379
I've got one for sale if you're looking. Just don't have the time to run it anymore.
http://www.rctech.net/forum/r-c-item...ml#post5718786
#9380
Attachment 444431
Attachment 444431
Hello,
Sorry but I didn't read all of the posts here. Did you check your L/R weight using balancing points before putting it on scales? I use scales for fine tuning only. The reason is that the scales are affected by the preload on the springs (obvious, I know). I have found that if I balance the car out evenly using balancing points I only need to make very minor adjustments to get the scales to read exactly the same at the tire. This is also assuming the car is not tweaked and that all of the shocks are the same length.
I use a Lipo plate and my battery is moved towards the outside of the chassis. Its dead level when I set it on balancing points and after setting ride height, droop, camber etc. I make some minor adjustments on the scales (or a tweak bar), check/reset the droop and I'm good to go.
Again, sorry if this was already brought up, just sharing how I do it.
#9381
help
thanks for all of you help it was the droop screws. I set the droop with all the shocks off ( I was told to do that). It really screwed up the droop. I checked the droop with the shocks on it and the car came out way better. Thanks
#9384
Ceramic bearings for TC5
Yes we do have a full ceramic bearing set for the Associated TC5. It's $89.99 and we don't use grease, only our SIN very light synthetic oil.
Thanks!
Thanks!
#9387
There is nothing wrong with adjusting it until it feals good IMO.
#9388
Hi guys, I just ran my brand new TC5 at the track today. I like it so much more than my used T1 I was driving before. Anyway, I did have one issue with it. My steering was bound up a considerable amount. After taking it home I found that the ball cups on top of the c-hub where tight enough on the ball studs to cause the problem. I may have over tighted the turnbuckles and crushed the ball cup end. My front roll center is the factory setup on the outside middle hole of the shock tower and I can only get -1.5 deg of camber. I'm gonna put new ball cups on the car and move the roll center to the inside middle hole to get -2 deg of camber, my usual. Hopefully this will fix my problem. Has anyone else experineced this. How will this affect the car's handling? It's a FT kit BTW.
#9389
#9390
Hey guys i was just wondering if any of you have tested diff height. If so can you share your findings on what this change does to the car. Thanks
