Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 02-04-2009, 05:57 PM
  #8746
Hyde's Avatar
Originally Posted by dr_hfuhuhurr
He gave you all the go fast tips for cruzing.
That and make sure you have plenty of stick on weights. Nothing that could look good, that would make your car slow for cruzing.
Are you trying to start cr@p with me??
Hyde is offline
Old 02-04-2009, 05:59 PM
  #8747
Trader Rating: 23 (100%+)
I think the guy on the left is Jim Varney. He used to play Earnest in tv commercials. He is from my hometown.
bmcallister is offline
Old 02-04-2009, 06:01 PM
  #8748
I want to see some closeups of some associated rides from the birds as well as some set-ups.
Old 02-04-2009, 06:26 PM
  #8749
Scottrik's Avatar
Trader Rating: 261 (100%+)
Nope...you've managed that just fine on your own. Go get 'em.
Sorry B., I can't think of his name, but that's not Jim Varney. The guy was a character actor in a lot of smaller roles through the 70's and 80's. Heck, probably still at it and I just haven't seen him in a while.
Hey Vern...
Scottrik is offline
Old 02-04-2009, 06:28 PM
  #8750
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
The Losi off-road piston's work without modification. Just do a test fit first to make sure that there is no molding marks left on the sides so that it could scrape the shock body.
Kraig is offline
Old 02-04-2009, 07:00 PM
  #8751
dr_hfuhuhurr's Avatar
Trader Rating: 95 (100%+)
Thanks Kraig.
Any other building tips for the TC5? I've read through most of the thread and haven't found a whole lot. I remember all the crazy stuff we would do to TC3's back in the day.
dr_hfuhuhurr is offline
Old 02-04-2009, 07:38 PM
  #8752
Lebatek's Avatar
Other than the basic building tips for any kit like wet-sanding and CA'ing the chassis and tower edges, make sure you compress the servo saver and diff springs with a pliers before assembly, etc., there' nothing too special you need to do. Make sure you get it balanced side-to-side, using one of the various methods discussed here. I also prefer to use longer 3mm cap screws in the suspension mounts...long enough that they actually protrude the outside edge of the blue alloy piece slightly. Good luck!
Lebatek is offline
Old 02-04-2009, 08:35 PM
  #8753
berserk's Avatar
Originally Posted by chrisfrom619
I believed they are available online as far as your local hobby shop you will have to ask them to order it for you.
thanks! I just bought my TC5R yesterday and im still waiting for it to arrive, hopefully this week. so im still researching for tuning tips for the TC5. im switching from tamiya 415 to associated TC5. mahal ksi ng 416.
berserk is offline
Old 02-05-2009, 01:13 AM
  #8754
chrisfrom619's Avatar
A friend of mine has a 416 and he would let me try it out this sunday he said it's really good but I have to see it first, coz the previous owner is having a problem driving it. I'm getting another tc5r this sunday from a friend of mine he only used it for two races. What are you going ot have on your tc5 (motor esc) and where do you race it.
chrisfrom619 is offline
Old 02-05-2009, 05:13 AM
  #8755
berserk's Avatar
we race in a very low grip parking lot. ill be using an LRP TC spec esc and vector x11 13.5 motor. pls check our site:
http://sites.google.com/site/saudiarabiarcclub/
berserk is offline
Old 02-05-2009, 05:18 AM
  #8756
Trader Rating: 3 (80%+)
Thanks Kraig.
Some servos are a little tight in the mounts.........I have heard that you can use the mounts from an ae off road car or I just removed some material from the mounts to move them closer to the servo.
Josh Hohnstein is offline
Old 02-05-2009, 05:44 AM
  #8757
I've got a BLS 451 or a 9550 to throw in there.
Old 02-05-2009, 06:46 AM
  #8758
Jerry P's Avatar
Trader Rating: 44 (100%+)
Do the Losi Pistons fit without modification or do you need to sand the pistons down a bit? I remember doing this back in the early TC3 days but can't remember.
Dr: They fit right in for me. I have them in both of my rides.
Jerry P is offline
Old 02-05-2009, 06:57 AM
  #8759
getpip's Avatar
Originally Posted by Scottrik
I removed the halding from my car as unneccessary balast. I found I was a lot more consistent without halding and it freed up space for important go-fast stuff like Phizer valves and muffler bearing.
getpip is offline
Old 02-05-2009, 09:52 AM
  #8760
geeunit1014's Avatar
Trader Rating: 14 (100%+)
you may have to take some material off for the 9550, I had to on mine. not sure on the 451
geeunit1014 is offline
