Team Associated TC5
#8341
I don't have a picture, no. You use a flat head screw and a cone washer above the top deck to hold it down. The o-ring goes between the cone washer and the top deck to allow a little bit of flex.
#8343
There is about 28.5mm of space between the top deck and the chassis.
Josh is running the Xray serrated flanged wheel nuts on his car, part #960240. I put them on mine as well (once he showed me what he was running) and they work great! No need to worry about getting enough thread to the nylon part.
#8345
100/44 for the 17.5 duo's would be a good place to start.
The timing in the speedo will have alot to do with gearing.......so check temps often as you change settings on your speedo.
#8349
Oneway for carpet
#8353
Thanks Rob
Do you by anychance know the Part # for the "Stealth Nut" ?? it seems that i have pulled the threads out on the ones supplied
Is this the correct 1 https://www.hobbyoutlets.com/store/hobby/6575.html?js=n
#8355
You know, pro drivers run spools on carpet and asphalt most of the time. A track has to have a very open and flowing layout for a one way to have an advantage. If the track is tight and twisty one way drivers will have to let off early to slow down for corners since they can't brake hard. A good driver with a spool can then run right past them, brake hard and pass them on corner entry every time.
You also have to ask yourself how you drive. If you are very disciplined and have good throttle control you can run a one way more easily. If you drive hard and really thrown your car around you will certainly be slower with a one way than a spool.
