Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 11-03-2008, 05:36 PM
  #7771
sonic31's Avatar
Trader Rating: 6 (88%+)
Originally Posted by beta bob
Hey guys finally broke down and decided to get a new car and the TC5R is the one i want for next summer season and i just wanted to know what on the car if anything should i replace or get a ton of spares for? thanks in advance.
you don't need any spares... just don't crash though ok.
just kidding. i would buy an extra set of the plastic suspension parts
sonic31 is offline
Old 11-03-2008, 06:03 PM
  #7772
Been doing tons of testing with the car and feel like i have made some huge gains on the car and very excited to run the indoor champs.
I am sending over my latest setups from the Halloween Classic. Felt like the car in the main was the best it had been all week long and should have been 2nd or maybe even 1st if not for my little roll over mistake...
Mike
Mike Blackstock is offline
Old 11-03-2008, 06:24 PM
  #7773
IH8Racing's Avatar
Originally Posted by PartTime
What r u running? Diff? Spool? Is it lose going into the corner or coming out? Need a little bit more info to help.
DK
I'm running the Slipper Spool. She drives like a champ! But somebody said the car was driving with the rear. I'm coming from off-road 2WD. I have no idea what to look for. The track I race at has a ton of people to offer pointers, they have been more then helpful. I really need to learn, I guess the proper terminology.
IH8Racing is offline
Old 11-03-2008, 06:36 PM
  #7774
Airflow's Avatar
Greetings...
Just some questions on the TC5:
Planned set up is 4WD street racer using non protoform/race bodies and
HPI street rims with HPI Advan copy radials, 3.5 brushless.
1. Does it use standard 4mm flanged lock nuts?
2. How can I increase ride height to 8mm? Ill be running on slightly
bumpy street pavement.
3. What are the weaknesses of the TC5?
Airflow is offline
Old 11-03-2008, 07:00 PM
  #7775
Maybell's Avatar
Originally Posted by Airflow
Greetings...
1.Yes, the wheel nuts are 4mm.
2.You might have to find some longer ballcups for the shock shafts to lengthen the shocks a little. Besides that you should be able to get 8mm height without problem.
3.If durablility is what your asking about, in my opinion the TC5 is the most durable top-shelf TC on the market. The only thing I have broken are rear hubs.
Maybell is offline
Old 11-03-2008, 07:18 PM
  #7776
Airflow's Avatar
Hey thanks for your response. Ill just use large steering ballcups for the shock shafts. And yes I was pertaining to the durability of the tc5. Straight line stability on street pavement is my concern, Ill go nitro hunting this coming holidays.
Airflow is offline
Old 11-03-2008, 07:22 PM
  #7777
MR1035's Avatar
Trader Rating: 29 (100%+)
Default TC5 parts
Originally Posted by Rick Hohwart
Are there any alloy parts TC5 owners would like to see released?
Yes the battery post...
MR1035 is offline
Old 11-03-2008, 07:54 PM
  #7778
artwork's Avatar
Trader Rating: 88 (100%+)
Rear hub carries (0 or 1 deg)
Front steering blocks
Are there any plans to release some?
artwork is offline
Old 11-03-2008, 11:21 PM
  #7779
ntc3racing's Avatar
Integy sales the aluminum steering blocks & rear hubs!!!
ntc3racing is offline
Old 11-03-2008, 11:29 PM
  #7780
ntc3racing's Avatar
I personaly got the integy aluminum steering blocks & diggity designs castor blocks!!!
Old 11-04-2008, 03:52 AM
  #7781
PartTime's Avatar
If I had to guess, I would think you have a ton of on power steering (love spools and oneways) You can move your front arms forward 1mm. That will settle it down a bit. You can take the shims out from under your rear camber link also. That will add a touch of rear traction. If the rear is just plain stepping out when you hit the gas, you might need to drop a spring rate in back to get the weight to trasnfer back. But would switch the shock pistons to #3 and put somthing like 50wt frt and 40wt in back before I changed the springs. The new piston/oil is more of a carpet setup than the #2/35wt your running. Really smooths the car out when the traction comes up. Just easyer to drive all around.
HTH
DK
PartTime is offline
Old 11-04-2008, 06:03 AM
  #7782
portyansky's Avatar
Trader Rating: 54 (100%+)
Originally Posted by Josh H
I have seen a shock where the black cartrage that holds the o-ring in does not stay seated all the way down in the shock.
Is it leaking out the bottom or top??
its leaking from the bottom.
portyansky is offline
Old 11-04-2008, 09:59 PM
  #7783
ntc3racing's Avatar
I think you need some o-rings!!
Old 11-05-2008, 05:56 AM
  #7784
Akhor's Avatar
In offroad,the manufacturer Integy makes parts with bling that do NOT have durability.. IS there onroad stuff better?
Akhor is offline
Old 11-05-2008, 08:18 AM
  #7785
Johnny Wishbone's Avatar
Default TC5 setup ?
When it is mentioned that the motor screw has been removed in the setup sheets, is that the screw that connects the motor plate from the bulkhead?
Johnny Wishbone is offline
