Team Associated TC5
#7786
I left it out on accident once and it cost me a spur gear.......so I always ignore that part of everybodys setups.
#7787
Rick,
Maybe not alloy parts but....................what would be awesome to see is some high velocity outdrives that don't chatter...like the ones that Losi uses in the Type-R and now Xray is comming out with for the T2. I believe this is a new innovation and to keep the TC5 competitive small upgrades/option parts need to be made to keep up with the competition and to keep TC5 owners interested. This is one of those changes...that will increase smoothness in the corners, increased steering and corner speed!
For example.....
http://www.teamxray.com/teamxray/sho...03bbc36ef572d#
For example.....
#7788
Sean do u plan on coming out to Camarillo this weekend to run some 10.5 I have a TC5R now along with Larry Ruby and a bunch of other guys. BTW the TC5R works out of the box at Camarillo I olny did a few minor tweaks to suit my driving style and she was dialed. Those outdrives would be very cool to have for a TC5
Josh Barry
Josh Barry
#7789
LiPO ballast plate.
Better battery hold down strap and blocks. #31254 & #31256
I am using a solid LiPO plate so I have to invert the REEDY 5000 Pack. Since the nubs were keeping the pack from sliding, I had to create a wider hold-down strap. Since the Pack is soo tall, I could not just poke the 4-40 threaded rod through the wider strap. I just ended up installing HeliCoils in the hold-down blocks and using a 4-40 cap screw in the hold down stap and LiPO. Without the HeliCoils, the Screw would pull through the soft plastic from repeated use.
Even if the holddown blocks were steel and not aluminum, I would still buy them.
Center Pully Holddown #31163
This is not much of a hassle, but I would like the uppper brace not to responsible for the direct hold down of the pillow blocks/bearing of the center pully. Maybe the pillow block could have some flanges that were screwed ontop and through the upper brace with button head screws. This would reduce the need for countsink tooling of 4 holes and should speed the change time of spur gears while not distubing the steering bellcrank or increasing CG.
Motor Mount BulkHead #31152
I would like to see the very upper top of the bulkhead milled with some heat radaitor vanes for some added heat disapation.
And Finally
A SETUP MANUAL like XRAYS HAVE. When I sold my xrays a few weeks back, I kept the Setup book.
#7790
#7791
#7792
Josh Barry
Josh Barry
#7793
A friend of mine is looking for a TC5F if anyone knows of one for sale. There is currently none in the for sale thread. Email him at [email protected]
#7794
-DC-
#7795
Josh H. and or Mike B.
How should a racer run with a one-way, rubber tire and carpet?
What style in the corners?
Thanks and God Bless
#7796
I guess the big thing is that you don't have to drive it into the turn hard. Meaning you can lift a little earlier and roll into the turn without scrubbing alot of corner speed.
Be smooth.........some turns require you to be completely off the throttle other turns you might need to be on the gas just a little.
It takes a little time to get used to driving with a oneway. The more track time you can get the better.
#7797
I tend to come too hard into corners still at times and wonder if the one way would make my tendancies worse (easier to traction roll)? If I give a small outside flip before the problem turn the issue went away...I wonder if I should practice that driving style more...some guys use it, others dont.
