Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 09-21-2008, 05:20 PM
  #7351
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
A Mazda speed 6 sedan body just finished up for a local!
...Jim
W.E.D.
W.E.D.Jim is offline
Old 09-21-2008, 05:42 PM
  #7352
Jsaves's Avatar
Josh,
Yeah they are the new greens, mounted on prizm wheels. They are supposed be softer than the blues.
When you say scary, what do you mean?
Thanks for the help
God Bless
Jsaves is offline
Old 09-21-2008, 05:54 PM
  #7353
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
OOoooh Jim, that shell gives me the chills!
rezenclowd3 is offline
Old 09-21-2008, 07:28 PM
  #7354
Trader Rating: 3 (80%+)
Originally Posted by Jsaves
Josh,
Thanks for the help
God Bless
When we were testing tires for vegas I had a chance to run the new green on the prizm wheel. Every time I tried them the car had so much steering that it was almost impossible to drive. We tried them on 3 different cars ......all had the same results.
Josh Hohnstein is offline
Old 09-21-2008, 07:38 PM
  #7355
AssocRacer's Avatar
anybody have a good rubber set up for a high bit carpet track that DOESN'T use the IFT chassis?
AssocRacer is offline
Old 09-21-2008, 09:11 PM
  #7356
artwork's Avatar
Trader Rating: 88 (100%+)
Originally Posted by Josh H
When we were testing tires for vegas I had a chance to run the new green on the prims wheel. Every time I tried them the car had so much steering that it was almost impossible to drive. We tried them on 3 different cars ......all had the same results.
Josh-
I have heard the same thing about the new R9-R Protoform body (lots of front traction). Have you tried one on carpet yet?
artwork is offline
Old 09-22-2008, 09:59 AM
  #7357
Originally Posted by RC_DAVE4
I managed to track down the issue. There is some slop between the hex bolt on the servo saver tube and the steering bell crank. The hex does not fit snug. I resolved the issue by using epoxy to snug up the fit between the two. This eliminated any pull I was having during full power.
Originally Posted by Mongy
Howdy,
Relatively new to RC cars, and very new to TC5s. Grabbed a second hand one recently and popped a 3.5 LRP in it. When driving it, found that when accelerating up a straight, the car would wander a little one way, then the other way.
Spoke to the guy I bought it off, and he said it was most likely the servo (was just a cheap Spectrum 590). So had mate at hobby store pop in a new one (Ace RC, not sure of model, was about $70 AUS).
There is a bit less wandering, but it is still there. Had a bit of a fiddle with the steering and noticed a bit of play on the ball ends. I've had someone else suggest getting some RPM ball cups. Not sure of model, but seen RPM 73381 as Associated replacements.
Does anyone have any other suggestions for the problem, or parts that might help a newbie out in fixing the problem?
Cheers
See my post above, I had the same issue it would pull to one side during acceleration in a straight line.
Dave
RC_DAVE4 is offline
Old 09-22-2008, 10:10 AM
  #7358
AssocRacer's Avatar
You know, i absolutely love the TC5, i mean...you get X-ray and Corrally performance for $150 less but i must say that for a high end touring car it does seem to have alot more slop in the parts then the other cars do. I too have that slop in the steering and when i change over to the ITF chassis i will have to use that trick to remedy the slop.
Old 09-22-2008, 10:17 AM
  #7359
Trader Rating: 38 (100%+)
Yeah the servo saver post just doesnt fit on the ITF chassis b/c that short little screw isnt quite short enough. You cant shim between the post and chassis b/c it raises the top deck. So I ended up using a really thin washer/shim between the screw and chassis. It is so thin the screw can go all the way down without sticking out but it makes up the difference.
or8ital is offline
Old 09-22-2008, 10:26 AM
  #7360
AssocRacer's Avatar
You could also take a dremel and grind off just a little bit off of the bottom of the screw that holds the steering post on.
Old 09-22-2008, 01:01 PM
  #7361
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Is it the screw that is to long or is it that the hole is countersunk in the chassis to much and there is not enough threads on the screw available to tighten it up?
Kraig is offline
Old 09-22-2008, 01:32 PM
  #7362
Yes, one of those I would suspect screw is too long since other screws fit fine with the same countersinking.
or8ital is offline
Old 09-22-2008, 01:56 PM
  #7363
AssocRacer's Avatar
Sweet, Amain actually had both ITF chassis places in stock. Josh, if you read this, YES i would have bought it from trackside if they had it in stock Kenny said it was on back order, and so did every other hobby shop local and online except for Amain. Just thought i'd head you off in case you would give me the lecture about buying from the local track like everyone else seems to do
Old 09-22-2008, 02:56 PM
  #7364
Originally Posted by artwork
Josh-
not yet art.............but soon
Old 09-22-2008, 02:57 PM
  #7365
Don't worry.............i'll find something else to lecture you about
