Team Associated TC5
#6991
I saw Juchas car and it had ridiculous cornerspeed in that sweeper versus the other stock cars. I really don't consider what Blackstock was doing since he ran modified, which is really a different ball of wax. Not to mention, it's really a moot point since he will be running an Associated car this winter.
#6992
Yeah that would be a very good thing
#6993
#6994
what spurs are u guys using? i bought a robinson racing 66 but it rubed on the upper deck?
U guys changing anything on TC5R to race mod?
Ran the TC5R yesterday for the first time was impressed..
#7000
Hi guys.
I am building a new TC5R this weekend. Out of all the touring car offerings I picked the TC5R due to cost, part availability and all the great comments here praising the car.
I will be running rubber on asphalt, how should I build the shocks up? I understand that I may not need the foam inserts that the bladders would be sufficent?
Also I will be running two motors, a 19T (open class) and a 27T (sportsman class) with the 87 tooth spur, any thoughts on pinion size?
Dave
Dave
#7004
Whats a good brand of spurs u guys recommended gettin?
How long do the spools normally last?
#7005
2: It depends on how good a driver you are and what types of accidents you have, like hitting walls or getting hit.
The Factory spool now has the slipper built in and it is supposed to help with blades lasting longer. If yoy have a solid spool you will go through blades quite regularly if you get hit or hit something.
I personally have just started using the Jaad spool with the delrin plastic cups and it is fabulous!! You do not thave to use blades with it and it seems to work very well!
