Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 08-06-2008, 03:25 AM
  #6781
NOZ69's Avatar
Just made the decission to update my trusty old TC4 to a TC5R..
What difference should I expect after driving shaft drives for sooo long and then going to belt drive???
Any set up tips.....my track is two concrete netball courts.
Cheers
NOZ69 is offline
Old 08-06-2008, 04:05 AM
  #6782
dawgmeat's Avatar
Get ready Bitches
Attached Thumbnails Team Associated TC5-dsc03098.jpg   Team Associated TC5-dsc03099.jpg
dawgmeat is offline
Old 08-06-2008, 06:53 AM
  #6783
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally Posted by dawgmeat
Get ready Bitches
finally Starling!, see yah sunday!
Marcos.J is offline
Old 08-06-2008, 07:09 AM
  #6784
yyhayyim's Avatar
Trader Rating: 26 (100%+)
No CS?
yyhayyim is offline
Old 08-06-2008, 07:21 AM
  #6785
rccrazy4587's Avatar
Originally Posted by Espo
#1 A domestic cars parts are always WAAAAY cheaper than a foregin cars. (ie. I almost hate my RDX because of the cost of parts alone...)
AE's are made overseas......
isn't everything?
rccrazy4587 is offline
Old 08-06-2008, 07:22 AM
  #6786
AssocRacer's Avatar
Cheers
First off, i've been out of the touring car thing for a little while, but what's the difference between the TC5 and TC5R? When i went from a TC4 to a TC5, the biggest difference i noticed was the power delivery, especially with a brushless setup. Much much smoother and more controlable power delivery cause the belt stretches and absorbs some of the torque. The car just handles much better then the TC4, it turns more. Much better car over all. My only complaint is that for a touring car it does have a bit of slop in the suspension components compaird to the X-Ray and Corally cars.
AssocRacer is offline
Old 08-06-2008, 08:07 AM
  #6787
Super Moderator
Marcos.J's Avatar
Originally Posted by yyhayyim
No CS?
sorry cant make it there a bunch of us running mod on sunday ,I spoke to PW and he is coming down too
Marcos.J is offline
Old 08-06-2008, 08:58 AM
  #6788
yodace's Avatar
Whats the diffs between a Spool and a front diff? Should i order the parts to convert the front to a regular diff..
yodace is offline
Old 08-06-2008, 09:01 AM
  #6789
Super Moderator
Marcos.J's Avatar
a spool you dont have any diff action, (this is a very popular set up for running rubber tires on asphalt)
Marcos.J is offline
Old 08-06-2008, 09:03 AM
  #6790
AssocRacer's Avatar
a spool is basically a solid axle
Old 08-06-2008, 09:06 AM
  #6791
yyhayyim's Avatar
There's a much more to this but in short, here's couple things...
Spool/Solid axle, both front wheels are locked, and spin together at the same time and speed, while the diff allows each wheel to spin each at different rate independent of each other. The diff will give you a bit more steering on corner entry, but the spool car can accelerate harder out of corners, and less maintanance, which is why most pros and joes run Spools for outdoor asphalt racing. Over the years racers have found out that running a front spool/solid axle is faster over all.
yyhayyim is offline
  #6792
AssocRacer's Avatar
Holy Sh1t!!!! 18,000 posts???? you must sit in front of the computer all day and do nothing but post on RCTech
Old 08-06-2008, 09:09 AM
  #6793
Hyde's Avatar
GET THE TC5. much smoother car. VERY stable in and out of turns. when you punch it out of a turn all the car wants to do is go straight and turn when you want it to on a dime. and not to spin out out of turns or in turn ins. NO more traction role. since the chassis is narrow the car is much more able to go straight at high speeds and not to spin out.
Cheers
Hyde is offline
Old 08-06-2008, 09:12 AM
  #6794
yyhayyim's Avatar
360 days X 10 posts per day = 3,600 posts per year X 5 yrs = 18,000
yyhayyim is offline
Old 08-06-2008, 09:19 AM
  #6795
Hyde's Avatar
yep 18k !!! he must have alot of rc smarts. i wish he was my big brother
Hyde is offline
