Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 02-26-2008, 04:56 PM
  #5401
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Originally Posted by RCpurplecow
OK, I'll try the ITF this saturday and see if my lap times get any better. I take it I should use Kyle Skidmore's setup only without the ITF chassis... to start.
thanks
You definately DO NOT need to run the ITF main chassis to get the car to work on rubber/asphalt. I have been using the ITF chassis and topdeck since June last year and have just recently switched back to the standard main chassis with the ITF top deck. This is racing on tracks here in Brisbane - Australia (very low to med bite outdoor asphalt tracks). I have found more cornerspeed and steering with this combo.
I have also started running with the hard plastic suspension components as well and this has made the car really consistent to drive fast as well as being much more sensitive to minor changes to setup.
In short:
  1. std chassis with ITF top deck is a great combo (fast and consistent) my choice pick
  2. std chassis with std top deck is okay at best
  3. ITF chassis with ITF top deck is a great for really low bite, but does suffer when grip levels come up
  4. ITF chassis with std top deck is okay (fast, but not consistent to drive)
These are my personal findings running on the tracks we have here. (5 cell mod - 3.0t or 3.5t motors) rubber tires on very low to medium bite outdoor tracks). I will post a setup soon (RC Tech doesn't allow excel spreadsheets )
- Leonard.
Hope this info helps.
DirtyDog3375 is offline
Old 02-26-2008, 05:07 PM
  #5402
RCpurplecow's Avatar
ArnO: Thanks for the link... GREAT SETUPS
Steve: Sorry I won't be able to make it this year. I'm attending a race at my local track, The Coliseum in Frederick, Maryland. I'll try to get a good setup based on some I've found.
Dirty Dog: I'm interested about your findings. I'll try to experiment with the different chassis configurations and see what I find is the best for high bite asphalt.
RCpurplecow is offline
Old 02-26-2008, 05:16 PM
  #5403
Dirty Dog: I'll try to experiment with the different chassis configurations and see what I find is the best for high bite asphalt.
High bite asphalt: use std chassis and ift top deck with hard plastic parts. (I believe this is the combo used at TITC by some of the AE guys - Drescher, Juho, and Abbott) I am sure they will confirm when they get back.
- Leonard.
Old 02-26-2008, 05:24 PM
  #5404
Trader Rating: 74 (100%+)
- Leonard.
Interesting,i have the hard parts on order i will do some expermiting.
steve eaves is offline
Old 02-26-2008, 11:22 PM
  #5405
Trader Rating: 14 (100%+)
At TITC Juho and Craig both used the ITF main chassis and ITF top deck. Both used the foam top deck for most of practice but then tried the ITF top deck and preferred it. I also ran the ITF chassis and top deck and preferred it. The stiff suspension arms allow you to feel a very small change to the car on the track and they were the preferred choice. RCS the track used for TITC was super high traction. The highest I have ever driven on. The car was very good indeed on this track. Juho was as quick as anyone else there, he just had very bad luck. Craig also ended up fast, he won the 2nd B final.
Andrew Abbott.
Miami is offline
Old 02-27-2008, 03:34 AM
  #5406
LOW ET's Avatar
Trader Rating: 109 (100%+)
has anyone had problems with the ae ball cups (rod ends)? i built one tc5 and they went together great. built a second tc5 and the ball cups kept spliting either at the ball cup or where you thread in the turnbuckles. the first kit the rod ends screwed on fairly easy but the second it was a nightmare to get them on. seemed like a different material or something.
LOW ET is offline
Old 02-27-2008, 05:14 AM
  #5407
Trader Rating: 38 (100%+)
button head or countersink screws for the top deck / o-ring mod? does it matter?
or8ital is offline
Old 02-27-2008, 06:20 AM
  #5408
Trader Rating: 90 (100%+)
Button head with a small washer is best, but you can use a countersink and it will still work.
RBLove is offline
Old 02-27-2008, 07:05 AM
  #5409
m8commando's Avatar
In short:
- Leonard.
I 100% Agree on the the chassis pick, I also run a standard chassis with a ITF top deck......and the car has been flawless.
I am also now experimenting Hard Parts on the car in asphalt conditions and the car is more hooked up. It feels like the car wants to stay in the turn more plus it seems to be a little more reactive, the C-hubs arn't flexing as much either. I am a firm beliver in letting the suspension due the work. I will be testing this setup again over the weekend.
I will post again my findings!
m8commando is offline
Old 02-27-2008, 06:47 PM
  #5410
Does anyone have a good base set up for BCR in Orange county. Its been so long i dont even remember whats in the shocks!
tcmerf is offline
Old 02-27-2008, 08:08 PM
  #5411
Question for a newbee TC5 owner. I'm brand new to on-road racing, did a bit of off-road a few years back.
I'm trying to decide on which way to go in the rubber tire class.
27t brushed
or 17.5 brushless.
I already have a GTB from my off-road car and after talking to a few folks around the track they suggested to go 27t brushed and just switch the GTB to brushed mode.
So last night someone gave me a used brushed motor and I hooked it up only to find the motor is buzzing like crazy and must be shot.
So my question, if you were a total rookie in on-road, should I just brake down and get the brushless 17.5? I've read it really tough to gear them with the TC's???
Any suggestions or advise would be awesome....
Eric
748eric is offline
Old 02-27-2008, 08:58 PM
  #5412
RedRocketRacing's Avatar
27t brushed
or 17.5 brushless.
Eric
Eric-
Just do what you can afford. We will see in a couple of weeks at the Nats on weather a 17.5 is faster or better than a stock brushed motor. If someone gave you a motor than maybe you can have somebody else have a look at it.
It is true that the 17.5 take a very tall gear. I had to run a 5.0 with a 110/40 or something for a 13.5. So, all in all nobody knows yet if the right way to go is a 17.5 or a stock. Good thing that you already have a GTB and can go either way. Might as well start with a brushed.
RedRocket
Anders Hagen
RedRocketRacing is offline
Old 02-28-2008, 07:54 AM
  #5413
t4mania's Avatar
Anyone have any pics of the electronics layout on this car. I'm trying to fit a GTB and a futaba receiver and man this thing is tight on space.
t4mania is offline
Old 02-29-2008, 02:09 PM
  #5414
Maybell's Avatar
I use Futaba receivers also and I had to place the receiver on its side when I installed my brushless system...thats all you should have to do...
Maybell is offline
Old 02-29-2008, 02:33 PM
  #5415
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
I was able to squeeze a GTB with Futaba receiver in there but I couldn't move the motor far enough forward to get the gearing I needed. So I changed the spur gear.
Kraig is offline
