Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 06-18-2007, 05:18 PM
  #3121
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Default Diff meltdowns
Just a note to all that are having issues with diff meltdowns:
the standard diffs work perfectly fine with low wind b/l motors (3.5t and 4.5t) as long as you take care when building the diffs.
1. make sure the diff plates are cleaned with motor spray
2. place 4 small blobs (equally spaced) of silicone grease on the outdrive - d-ring area
3. make sure the diff plate is facing the correct way (sharp edge towards the outdrive -facing down away from the pulley)
4. build diff as per instructions (diff spring precompressed)
5. make sure the diff is tightened properly
Hope this helps. (it has solved my initial issues)
- Leonard
DirtyDog3375 is offline
Old 06-18-2007, 06:01 PM
  #3122
SpeedTech's Avatar
Hi Guys,
Just want to post a quick note that our Titanium screw kit for the TC5 are available now.
Steve Wang
SpeedTech is offline
Old 06-18-2007, 07:20 PM
  #3123
Three's Avatar
Hey EA!!!
Will you be at the Memphis "Beat the Heat" race on June 21 and 22??? Sure would like to see the TC5, all they seem to run here are Losi and X-ray...
Three is offline
Old 06-18-2007, 07:34 PM
  #3124
Originally Posted by Advil
The Futaba 9550 and the KO 2343 do not fit the kit mounts.
I was able to mount my Futaba 9550 without any modifications.
home13oy75 is offline
  #3125
I ran a week ago at cefx and was very happy with the car. I posted hat I came up with for a setup a few pages back!
Originally Posted by Glowster21
How has the car been performing on carpet? Thinking of getting one to try but I only run on the rug and want to get some opinions before I take the $350 plunge.....
walterhenderson is offline
Old 06-18-2007, 11:19 PM
  #3126
Verndog's Avatar
Trader Rating: 16 (100%+)
Interesting, my 9550 no way was going on. I had to grind down the side of the 2 servo mounting blocks. Turned out fine, but blocks against sides of servo was too wide. Possibly you got some narrowed mounting blocks?
Verndog is offline
Old 06-19-2007, 12:19 AM
  #3127
tc4wally's Avatar
May i just say that as an aussie, cannon does not represent us as a country or a race group. Most of us are nice people that, whilst we have opinions, are open to listening to others aswell.
tc4wally is offline
Old 06-19-2007, 03:29 AM
  #3128
ooliganRC's Avatar
Originally Posted by mi2dude
does this mean ill get a frre new one?
also i have found the car to be excellent one thing thou... got a slight knock front diff bearing holders....they are clean and no burrs... im running a bd spool and pulley, but it did the same with my tc5 front diff.....
any ideas.... doesnt effect performance, is just annoying
no ideas then
ooliganRC is offline
Old 06-19-2007, 02:03 PM
  #3129
corallyman's Avatar
Trader Rating: 101 (100%+)
no ideas then
Can you describe in more detail, that might help.
Steve
corallyman is offline
Old 06-20-2007, 01:56 AM
  #3130
ooliganRC's Avatar
Steve
ok , sounds like a chattering you would get from full steering lock.
its definately coming from the front diff bearing housing and cam....
i have taken them apart and checked for burrs, damage but nothing.
it occurs when you rotate the drive chain, its noticable at low speed...a very mechanical sounding ticking noise, and its rotational speed sensitive ( faqster it spins the noiser it is)
bearings are new, its got me confused.
no noticeable effect on performance thou
Old 06-20-2007, 02:38 AM
  #3131
corallyman's Avatar
A few people have posted that they have a clicking noise in their car also but some team drivers have said that the pins in the spur gear shaft can move inside the pulleys and click around some but still be secure inside the (20t) pulleys. If you were to take those pieces apart and puts some diff grease in there, just a small drop, that should hold those pins from making noise and then you could see if that fixes the noise.
On my car I don't hear any noises at all, but I havn't run my car yet either.
Steve
Old 06-20-2007, 02:43 AM
  #3132
corallyman's Avatar
If you're still convinced that its in the front of the car, then switch the bearings, cams, and diffs to the rear and of course bring the rear stuff to the front and see if its still there. I know its extra work but by doing this you would start eliminating what it could be.
Steve
Old 06-20-2007, 02:45 AM
  #3133
Castradamus's Avatar
Trader Rating: 62 (100%+)
Originally Posted by cannon
THe point I make is that you are not allowed to criticise an "American poduct" . People should be aware that the kit is a long way from perfect
I understand that you may be upset with the quality but there is no need to use that as a chance to criticize ALL AMERICANS. Don't you think that there is a enough seperation in this world. Why can't we just be Hobbyist and leave it at that?
Castradamus is offline
Old 06-20-2007, 03:51 AM
  #3134
burbs's Avatar
Associated is an american ompany, but it is owned by thunder tiger which is not.. I also was told all of the parts are made in china now.. So as far as i am concerned they can keep the red white and blue on the lable, but it is not an american company anymore..
Now dont take this as a dig cause i love associated products..They have been the footstone for most of the rc we have today..But american company i think not..
burbs is offline
Old 06-20-2007, 05:49 AM
  #3135
highwayman's Avatar
did anybody "bookmarked" the comparative spring rate guide? thanks - jason
highwayman is offline
