Tamiya TRF420 Thread
#571
#572
I am an indoor black carpet guy mostly,
i ran the 420X carbon car this weeknd on fairly low grip asphalt in 17.5 TC
the locals are all multi- ROAR national champs, so the bar is set high
The car had amazing rear grip, almost too much , , I started at 3deg rear toes, backed it down to 2.5 deg
i ran flex mode with the rear bearing installed for the top deck
i would rather my car to understeer a bit that oversteer at those speeds
on the front of the top deck i had 2 stiffner bolts installed
the car was fun to drive, predictable , and fast, the area to work on for me, which will be track temp depending is off center of the corner rotation,
i could probally acheive this with less rear toe, and then and a screw to the motor mount if i needed to snug up the rear
#573
I am wondering if I should pull the trigger now to upgrade from my 420, or skip this generation. Here in Germany inventory is getting low – most shops already list it as "out of stock". Will Tamiya produce more of the 420X or is a successor imminent?
#574
interesting quest, I have been looking for a Tamiya FF04 Evo in blue, but did some measurements, and some mock ups, the next 420 will probally be true mid motor, with only a top deck change and belt lengths.. thats it minus a couple of holes drilled into the chassis for the motor mount
I am gonna make a 420XF ( my version ) for FWD racing, and i plan to hurt some feelings
#576
- TRF 418 Dec 2013
- TRF 419 Dec 2014 – 1 year
- TRF 419X May 2016 – 1 year 5 months
- TRF419XR Dec 2017 – 1 year 7 months
- TRF420 Dec 2019 – 2 years
- TRF420X May 2022 – 2 years 5 months
- TRF??? potentially Dec 2023 – 1 year 7 months
#577
I hope you're right! If I look at tamiyabase.com and the release date of the TRF touring cars in the past 10 years and the time between them I get this release cycle:
- TRF 418 Dec 2013
It’s Tamiya however, they beat to the sound of their own drums
