Tamiya TRF420 Thread >
Like Tree423Likes
Old 11-12-2023, 01:27 PM
  #601
zuqbu's Avatar
A little race report
I haven't had much experience with the TRF420 as I bought it and then set it aside because I was focused on the TB-EVO8. For our upcoming local club race I decided to switch to the TRF420, as the rules are very open and most importantly don't require a minum weight. The TB-EVO8 drives well, but it is in race trim around 80 grams heavier than the TRF420 …
At our local club we race with fixed timing, motors (17,5T) all tuned to 19.000 rpm @ 8.4V, same tires and (as mentioned) no minimum weight limit. The field is incredibely competitive, apart from 3 aliens who are two tenth per lap above everyone else, everyone is in the same ballpark. Today we had 16 people at the race and the difference between the fastest overall lap between P4 and P16 was between 0.2 seconds on the fastest lap. Unfortunately I had to forfeit my first qualy after a crash (I am not the best driver) and also was not performing as well as in practice in the next two so I ended up in the C-Final.
But being there meant I could cruise to an overall second in C with a win in the last race. Just to give you an idea how stacked up the field is, in the final race I did 65 laps in 10 minutes which would have put me on 5th place in the A-Final where the 5th running car was doing 64 laps, with a best lap also within a hundredth of mine …
Overall I am happy with the performace of the car, with a better driver it could have placed high in the A-Final But the TRF420 (non-X!) was on pace with all the ARC, X-Ray and Awesomatix the rest of the pack was running.
zuqbu is offline
Old 11-20-2023, 09:04 AM
  #602
Originally Posted by snopro31
does anyone want the 54887 rear toe control ? I still have stock on them pm me
Been looking for these - pming you now.
jessele is offline
Old 12-08-2023, 11:25 PM
  #603
kentech's Avatar
TRF display at 2023 Tamiya Challenge Cup Final Race in Japan this weekend, showing the cars used at the JMRCA All Japan TC Championship two months ago.
More: https://kentech.wordpress.com/2023/1...-special-cars/
zuqbu likes this.
kentech is offline
Old 12-09-2023, 09:01 AM
  #604
kentech's Avatar
Raman likes this.
kentech is offline
Old 12-09-2023, 09:51 AM
  #605
zuqbu's Avatar
Thanks for sharing, can't wait for the inevitable next TRF car. Just hoping Tamiya never releases anything with those awful-looking 3D-printed bumpers
kentech and angrymelon like this.
zuqbu is offline
Old 12-09-2023, 02:19 PM
  #606
Zero Tribe called, they want their conversion back.
TheMessiah is offline
Old 12-15-2023, 08:03 AM
  #607
Default Cheap ARS (maybe too cheap...)
With the rear axis of my TRF420 I have the problems that even though right and left side are built absolutely symmetrical I have different toe readings, sometimes up to 1°. I thought about getting the ARS system but unfortunately it is really expensive (>100€ in Germany) and right now not even available. I thought about a cheaper alternative and designed a flexible hub which I connected with a thread rod to the chassis. From an assembly point of view it seems to work. I used inserts for 1,5° of toe-in and then adjusted both sides to a final toe-in of 2,5°.
From a driving and durability point of view I cannot say anything so far. Obviously the flexibility is not just present in the desired directionJ. It might make up for some interesting behavior of the car…. If it is way too soft I plan to fill the gaps with silicone or similar.
Unfortunately I will not be able to really test the car until April.
Does anybody know if some company has tried such a solution before?
AndreasHerold is offline
Old 12-15-2023, 08:08 AM
  #608
Default Just another pic to show the concept
Old 12-15-2023, 08:22 AM
  #609
If you have a 3d printer … wouldn’t it be easier to design a normal hub but design it to accept hinge pin inserts? Create several inserts with incremental angle differences, going both ways, and use these to adjust your toe for each side.
malkiy is offline
Old 12-15-2023, 11:16 PM
  #610
h2e
h2e's Avatar
Default rear ARS
Has anybody got a TRF420(X) AND a TA08 to check if the rear TA08 arms would fit a TRF? Maybe the upper arm truangle could be done with some double turnbuckle parts you could mount them on the upper bulkheads?
h2e is offline
Old 12-15-2023, 11:44 PM
  #611
Well, I do not have 3D printer and rely on online print services. Don't get me wrong: Even with the original car I was able to get the toe-in to the reading I wanted. I just had to replace the bushings often enough an measure again. I wanted a solution that allows for fast adjustability without replacing parts.
Regards,
Andy
Old 12-16-2023, 08:46 AM
  #612
Raman's Avatar
Trader Rating: 96 (100%+)
someone on Facebook on the TRF group did make it happen. They didn't follow up with any further details. I don't think the TA08 arms offer a better geometry.
rccartips likes this.
Raman is offline
Old 12-20-2023, 09:34 AM
  #613
Casey's Avatar
whats parts are used to accomplish this ? what car are they from ?
Casey is offline
Old 12-20-2023, 11:12 AM
  #614
Raman's Avatar
Raman is offline
Old 12-20-2023, 11:40 AM
  #615
Suspended
Trader Rating: 76 (100%+)
From the picture it is using the front turnbuckles from a TRF 414M on the back.
Metalsoft is offline
