Silver Can Motor Tips/Tricks
#737
Rafaelli- Try 10/13/18/20 amp settings, all at 5 volts. You shouldn't burn up any motors with those settngs and it would be highly unusual for a silver can to pull much more than 20 amps in a Mini. Possibly more in a GT3, but I set my amp limiter at about 20-22 amps and the car never stutters in GT3.
#738
Thanks. I will give it a shot this weekend.
#739
huh???
AS FOR THE 23T TAMIYA SPORT TUNED ARMS INSIDE A MABUCHI CAN I THINK ITS IMPOSSIBLE I HEAR PEOPLE HERE TALK ABOUT THIS AND YOU ARE THE ONLY ONE IVE HEARD THAT SAW OR KNOW ON HOW TO DO THIS P.M. ME.
ITS NOT A SILVER CAN WAR
ITS A ESC, BATTERY, BATTERY CHARGE, SET UP, KIT AND SKILLS WAR...
#740
10 feet
#741
23t silver can
Any guys here can really effectively tell me how a silver can motor can be reversed engineered to put an armature of a 23t ie sports tuned into a silver can motor.
Or even can you guys explain me how this goes. Even how to put the cap out of the silver can...
This all serves as R&D for me
I would like to know what other possibilities are out there that I might not know
#743
HMMM?
HOW
but it's not that hard to get them apart. You could certainly make it "not obvious"
HOW
OUT OF MY CURIOUSITY
#744
Hi,
10 feet, other factors not mentioned...
1. More camber, less tire friction, higher top speed.
2. Less rear toe in.
3. Aero body.
4. Gearing.
5. Steering is perfectly straight. No wavering and scrubbing speed.
6. Stuffed tires. Hard tires, less rolling resistance.
Im sure there are more. Fast guys, please share to show it is not really cheating.
joel
3. Aero body.
4. Gearing.
joel
2. You have a choice of 0, 1 1/2, or 2 degree rear uprights. I believe the TCS
Champ. was using the 2 degree uprights. Surely he qualifies as a "fast" guy
3. Not legal
4. Not legal
5. Ever try to drive a Mini straight with 0 degrees of toe out.'
6. Everyone, and I mean everyone does this. but most go softer on one end or the other
Do you have or have you ever driven a Mini????? It's no wonder they pull you by 10+ feet. First with that aero body and illegal gears you'd be cheating and wouldn't make out of tech. And if you had the right gears and proper body, and you had hard tires all around, 0 degree blocks in the rear, and had your front wheels at 0 degrees toe in or toe out, this is what you Mini would drive like. It would wander down the straight almost uncontrollably unless you slowed way down and would spin out except at very slow speeds. If you've got a Mini set up like that, you'd better get some help fast before you destroy your car. Betteryet, check out Devin Whites set up in the Mini Cooper thread.
#745
He's a champ in mini
1. It's not adjustable
3. Not legal
4. Not legal
3. Not legal
4. Not legal
#746
The end bells are just crimped in. Just use some small pliers and undo the crimps and pull the endbell out. You can re-crimp it (stake) it back in.
If you put it side-by-side with another (unopened) motor, you would no doubt notice that the crimps were different, but if you did it carefully, it wouldn't be totally obvious.
#747
That he may be, but the camber on a Mini is still not adjustable, aero bodies, and changing the gearing are still illegal, and O degree front and rear on hard tires all around will still make your Mini nearly undriveable. If everyone where I race, had their Minis adjusted that way and had stock gearing and bodies and the stock NONADJUSTABLE camber links, I'd be untouchable, that is if I could avoid all of the weaving and spinning Minis. However, I will admit that I certainly could be wrong and would suggest if anyone wants to try that setup to do so, except for the illegal stuff. None of the fast guys I know run a setup like that and they include the TCS Champ, the 2nd Qualifier, another A main Qualifier, and A couple or more who were in the B main at the last TCS Nationals. As for me, no thanks, I'll listen to those guys.
Sorry, I forgot the MO3R has rear camber links that are adjustable, but only circa .5mm in a useful direction
#748
Faster
