Like Tree347Likes
Tamiya M-08
Old 05-18-2022, 06:01 PM
  #616
Raman's Avatar
Trader Rating: 89 (100%+)
Originally Posted by Snoozeym
Thanks. By drag brakes do you mean the auto brake function on neutral position in some ESCs?
Yes.
Raman is offline
Old 05-18-2022, 06:18 PM
  #617
Originally Posted by Raman
Yes.
I get really bothered by drag brake. Drag brake makes the car a bit over-steery when I'm looking to roll through a corner. I do some really severe expo on the brake curve instead, and set the max to like 40%.
Nerobro is offline
Old 05-18-2022, 06:28 PM
  #618
The m08 can be very capable in high traction tracks....
bertrandsv87 is offline
Old 05-19-2022, 07:57 AM
  #619
Raman's Avatar
For M08, I don’t use brakes or drag brake. I let off throttle prior to entering turn, and gently squeeze get throttle right after I enter turn and modulate throttle through turn.
Raman is offline
Old 05-19-2022, 09:25 PM
  #620
This may sound like a dumb question...but is there a big difference between the 80amp ESC and 60 amp ESC from hobbywing? Just plan on club racing with a 2S 120C battery and a 21.5 Reedy motor. Am I at a disadvantage if I run the 60amp version?
Flare65 is offline
Old 05-20-2022, 10:50 AM
  #621
Raman's Avatar
Not for an M chassis and a 21.5 motor. Higher amp makes difference when you’re running a 13.5 or lower turn motor
Raman is offline
Old 05-21-2022, 11:28 AM
  #622
I am a total rookie when it comes to on-road racing and would like to get an M08. My track is a tight, black carpet setup. In an effort to keep costs down, I want to run a Torque Tuned motor and run the car in a box stock setup. What shock springs and oils should I have in my parts box and what would be some good tires to try? Nobody runs mini at the track so I can’t ask locally. I don’t plan on racing, so just looking for a fun car to drive (and I like the smaller mini-sized car).
CTRJ is offline
Old 05-21-2022, 12:24 PM
  #623
Raman's Avatar
this is more or less my current setup for black carpet.
ride height 5 front, 5.2 rear. Front:
350 damper oil
Soft Red spring (42168)
4° caster
1° camber & 1° toe-out
Rear:
400 damper oil
Medium Yellow spring (42168)
1,5° camber
gear diff, start with 10k and go up from there.
Rear toe you can run the kit set up and it will be fine.
Raman is offline
Old 05-21-2022, 06:03 PM
  #624
Thank you Raman. Are your shock settings for the stock plastic shocks? Will the kit tires work or should I get something different?
CTRJ is offline
Old 05-21-2022, 08:23 PM
  #625
Raman's Avatar
Theyre not, but kit ones will work just fine. Kit are decent shocks
Raman is offline
Old 06-01-2022, 09:01 PM
  #626
Tamiya S Grips are out of stock everywhere. Any alternate tires I can get for black carpet that are readily available in the US?
CTRJ is offline
Old 06-02-2022, 08:06 AM
  #627
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
54999 and 54995
I also have a lightly used Ride set for sale. Some people still have preference for those.
Dan is offline
Old 06-03-2022, 01:03 PM
  #628
I managed to secure 12 sets of S-Grips for about $7 a set. I am good for a few races
Raman likes this.
Zanquis is offline
Old 06-03-2022, 02:16 PM
  #629
Raman's Avatar
12 sets? They will last you till you enter retirement 😂
Raman is offline
Old 06-03-2022, 05:03 PM
  #630
Tamiya's type A slicks with hard inserts work really well on black carpet.
Roken is offline
