Like Tree416Likes
Tamiya M-08
Old 06-05-2022, 04:53 AM
  #631
Anyone know where to find replacement bumpers for this car? Or know any alternatives that mostly fit?
herrokero is offline
Old 06-07-2022, 12:47 AM
  #632
You could get 54819 bumper XL it's big enough to cut out one for M08.
Roken is offline
Old 06-16-2022, 09:44 AM
  #633
Do you guys know if the body holes from a M05 are the same for the M08? IE, Can I use the same body for both cars?
CTRJ is offline
Old 06-16-2022, 04:04 PM
  #634
Raman's Avatar
Trader Rating: 94 (100%+)
front are the same. Rear on M05/M06 were flipable. The M07/M08 is only the forward position
Raman is offline
Old 08-18-2022, 07:56 AM
  #635
xpressracer's Avatar
Default Ball diff vs. Gear diff
I have the M08R and plan on racing on black carpet, would it be better to use the Gear diff?
xpressracer is offline
Old 08-18-2022, 08:37 AM
  #636
Raman's Avatar
Gear diff
Raman is offline
Old 08-18-2022, 08:39 AM
  #637
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Agreed. I did not even touch the ball diff in the M08R. I installed a gear diff I had laying around on the initial build.
Raman likes this.
Dan is offline
Old 08-18-2022, 09:07 AM
  #638
Thanks for the input, I will get one on order.
Old 08-18-2022, 07:56 PM
  #639
Raman's Avatar
As for the weight, you need to play around. 2020 I was one fire with 40k. 2021 I was struggling, so I settled on 15k.
Raman is offline
Old 08-19-2022, 07:34 AM
  #640
I think that's where I will start, at 15K
Old 08-19-2022, 03:07 PM
  #641
Dan
Dan's Avatar
Anyone built an M08R recently? I built mines up and my rear toe-in is not symmetrical left/right on the setup station. The time, it is the opposite of my other M08 in regard to adding shims on one side. Urghs...
Using the plastic suspension arm mounts this time versus aluminum on my other M08.
Dan is offline
Old 08-31-2022, 07:22 AM
  #642
zuqbu's Avatar
I just ordered and want to build a M-08R for the indoor season, what are the suggested hop-ups I should get? I guess the 54757 stabiliser set is more or less required, and would you recommend the included ball diff or should I get the 54471 gear diff?
Also, which spare parts should I stock up on? Anything that breaks easily on this car?
zuqbu is offline
Old 08-31-2022, 08:57 AM
  #643
Raman's Avatar
pick up gear diff. I recommend you switch to the M07 C hubs and suspension plate. The M08 with inserts is fragile. While your at it keep suspension arm spares.. and you’ll be good
zuqbu likes this.
Raman is offline
Old 09-04-2022, 06:45 AM
  #644
ran one of this, could be a good alternative for mini rwd, it is a conversion from M05 with modified spur gear that can achive lower than 3;1 gear ration. it does have 210 and 225 version.
gwhiz likes this.
rcpinky is offline
Old 09-04-2022, 11:09 AM
  #645
Dan
Dan's Avatar
Who makes that? Almost looks like a race version M04
Dan is offline
