XRAY T4'19 SPEC
#451
I have a 19 that I run mod on black carpet. I also have a 15 I run on the same stuff with a 21.5 TC class. The 15 is absolutely up to that class and more but I'm glad to have the 19 for mod. I also have a 15 for mod tc on asphalt and don't see a reason to change yet.
I would guess that switching my 21.5 car to a 19 chassis wouldn't show any real improvement in my hands.
#452
Is there a place to check compatibility between cars? Just wondering what the cost of a new chassis for the 15' would be or if I could use an updated chassis.
#455
My buddy has a brand new Xray 2015 carbon chassis. PM me if you are interested in buying it. Pretty sure he would let it go for pretty cheap since he installed an aluminum chassis from the start.
#456
Suspended
Looking good. Double check the direction of your layshaft. The spur screws should be on the short belt side. Easy enough to fix, just flip the whole shaft assembly side for side.
#457
Suspended
https://www.teamxray.com/teamxray/pr...XRAY%20T4%B419
#458
Thanks for the "heads up". Yes, it was on backwards. The image in the manual was small enough that it was difficult to tell. I should have used a flashlight (as I usually do when small print in a manual is difficult to read/see), but I thought I was correct...and, I wasn't. It's corrected now, and about to proceed to step 3.
#459
#461
What's going on? Normally you will see some setup sheets after an ETS, now nothing. I'm waiting for some time now. Hagberg's sheet gives a 404. Jan's setup only pictures, no sheet.
I'm looking for some asphalt setup sheets for some inspiration, I need to get rid of a rear which is stepping out a lot. This could also because the track was quite dusty.
#465
Not quite finished...but almost.
With the exception of the servo & motor fan, electronics still need to be installed, followed by painting the body, and finally wheels/tires. Due to work (something has to pay for all this stuff), it took much longer than expected...but it's almost finished...except for one problem. One of the plastic eyelets for the anti-roll bars was "defective", so awaiting a r we placement from XRAY.
Can't wait to get the electronics installed, and get this chassis outside. First order of business - aligning the steering/servo. For my first on--road vehicle, I'm quite happy. I did, however, discover a "problem" work the directions. In regards to installing a motor fan, that should appear WAY earlier in the manual. Instead of being on the last page, it should have been included when installing the motor mount. Other than that, excellent build manual.
