Like Tree272Likes
XRAY T4'19 SPEC
Old 02-06-2019, 09:33 AM
  #301
Originally Posted by OttoKrosse
Google '2019 Xray T4 set up sheet', or go to Petit Rc.com and look up Xray T4 there, you can also go to Xray's website and get a manual downloaded
thanks i will do this. i see your puting shims under the upper deck why may i ask.
SGrubb is offline
Old 02-06-2019, 12:09 PM
  #302
OttoKrosse's Avatar
I stopped using shims under my top deck awhile ago, it tends to soften the feel by allowing for more flex in the chassis, I like an aggressive feel....too soft and I feel it's lazy going into the turns. On Petit RC check some of the set ups from top drivers on the surface you race on....and hit up local racers with your chassis for specific tips for your track. Most racers will share their set ups.
dawgmeat likes this.
OttoKrosse is offline
Old 02-06-2019, 06:58 PM
  #303
theproffesor's Avatar
Trader Rating: 66 (100%+)
Are the locating pins on the bulkheads steel or aluminum?
theproffesor is offline
Old 02-07-2019, 05:31 AM
  #304
dbbs.decals's Avatar
been looking for this page. Is anyone running 21.5 with the 19, if so what gearing?
dbbs.decals is offline
Old 02-07-2019, 06:56 AM
  #305
Depends on the track really. Mine is at 3.8 FDR
TJD8521 is offline
Old 02-07-2019, 12:00 PM
  #306
OttoKrosse's Avatar
2 biggest factors are track size and motor, with some of the new motors start around 4.0 and adjust as needed.
glennhl likes this.
Old 02-08-2019, 05:11 AM
  #307
We run locked can reedy or hobbywing and start around a 3.0 for our 50x100 track.
anthonyscardina is offline
Old 02-09-2019, 05:12 PM
  #308
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
anyone looking to sell a 19? lmk!
JEFFs SC10 is offline
Old 02-12-2019, 06:51 PM
  #309
Thank You.
Old 02-12-2019, 06:53 PM
  #310
Not 100 percent sure how big our track is. I run at RoadRunners in camarillo ca. I have a maclan v2 21.5
Old 02-12-2019, 07:33 PM
  #311
tbrymer's Avatar
Start at 3.88 and around 42-50 degrees and go from there.
glennhl likes this.
tbrymer is offline
Old 02-12-2019, 08:58 PM
  #312
good advise right here!
trigger is offline
Old 02-13-2019, 06:08 PM
  #313
Default Chassis tweak
Have a fairly newbie question. I have a aluminum flex chassis for T4 2018 with nothing attached to it (the car has been completely disassembled). When laid on a flat surface, on the rear of the car I can squeeze a 0.5mm shim under the car and can do so for about 12mm (18mm) inwards from the rear on the right (left) side. Is this going to have a significant impact on driving/setting up the car? Anything that could be done to correct this or I have to buy a new chassis pretty much?
Thank you very much for responses!
chajnik is offline
Old 02-13-2019, 06:17 PM
  #314
DaSilva3525's Avatar
That is a pretty good amount. How much is noticed is debatable between racer to racer but trying to have it flat as possible with no tweak is Ideal. My best method to date has been to sandwhich the alum chassis between a good set up board and a thick piece of glass on top.. with 40-50 lb worth of dumbells resting on it for a few days or even a week. Trying to flex the chassis back with your hands is never really going to work. Spreading the load evenly with some weight does the trick for me. (sorry for the terrible pic quality)
Ggrant and johnzhou2476 like this.
DaSilva3525 is offline
Old 02-14-2019, 03:05 PM
  #315
really? Does this really work? I though aluminum has memory and you have to over bend it to get it straight
johnzhou2476 is offline
