XRAY T4'19 SPEC
#331
Just a thought, but maybe lift a little in the sweeper. Maybe you're trying to force the car too much. Like I said, just a thought...
#332
Suspended
Yes, Jan's snowbirds setup should be good to go with. If that is still tipping, please let us know.
Does the tipping go away as the run goes on? Or does it lift the whole run?
#334
Jan uses the flex chassis,do you think that I can use the flex or do you think I need the full aluminum and what is your opinion on using the flex compared to the full aluminum
thanks
#335
The more you run the more tipping you get. you think puting glue on the back tires will help. or just start over with jan's setup first.
#337
Suspended
There is nothing available yet. It is still being developed.
#338
[QUOTE=R Dodge;15400434]This is a tricky question these days. My local track is pretty high bite, so I prefer the solid chassis there always. It seems a lot of the big races lately are not very high bite, or the surface ends up becoming greasy for whatever reason. In those conditions, a flex chassis is good as Jan has shown at IIC and Snowbirds. I did not attend IIC, but I ran a solid chassis at Snowbirds. Both of our cars were pretty good there, so it seems either chassis can work.
Interesting. Yes, try Jan's setup and let us know how that goes. Don't glue the rears yet, I don't think that will solve this issue
R Dodge i tryed jan ratheisky setup and all the car did is traction roll. had toput more glue on the tires.
There is nothing available yet. It is still being developed.[/QUOTE
#339
Suspended
SGrubb,
Can you confirm, this is the setup you ran?
http://forum.teamxray.com/xform/inde...&setup=t4_2019
#340
SGrubb,
#341
Suspended
The order I would make changes is 1) move the arms, 2) change rear springs, 3) raise the topdeck.
Of course, more glue works but typically we try to stay in the 58-59mm range.
Hope this helps.
#342
Hey Robbie, how about you "unlock" your set-up. Just interested to see what you're doing with the car. My usual go to set-ups are based off Alexander's...
Darryl
Darryl
#343
Suspended
That one is still a work in progress. Maybe after ROAR Nats I will have something to share
In the meantime, I am attaching my setups from Stock Wars and Snowbirds. Stock Wars was on medium-high bite with Gravity tires. Snowbirds was on low-medium bite with Jacos.
#344
Hey Darryl,
#345
Suspended
