Like Tree272Likes
XRAY T4'19 SPEC
Old 02-14-2019, 04:32 PM
  #316
DaSilva3525's Avatar
Originally Posted by johnzhou2476
really? Does this really work? I though aluminum has memory and you have to over bend it to get it straight
I've done this multiple times and each result has made them stuck to my set up boards nice and flat. You have nothing to loose to try it. I have ocd and if my chassis are tweaked I have to have them go straight. I have a spent a couple hundred or more on chassis base plates in the past. Now I use this method, can even have them in rotation between maintence sessions. If it starts with a super bad tweak you may not get it 100% but very close.
my .02
mracer1, Ggrant and johnzhou2476 like this.
DaSilva3525 is offline
Old 02-14-2019, 05:41 PM
  #317
dasilva is just showing off that he lifts.
​​​​JK, seems like a good method. Will try if it tweak my chassis.
DaSilva3525 likes this.
s14_tat is offline
Old 02-17-2019, 09:54 AM
  #318
Trader Rating: 16 (100%+)
You are correct. If you have tweaked a piece of aluminum, it has yielded. You will need to yield it in the opposite direction for it to be able to be able to spring back and be flat.
sps3172 and DBM like this.
glennhl is offline
Old 02-18-2019, 08:45 AM
  #319
I raced my car for the first time this past weekend i ran 17.5 stock the car would come off the two in side tires in the sweeper i have glue on the front tires i run on black carpet .
SGrubb is offline
Old 02-18-2019, 10:54 AM
  #320
Iketruman's Avatar
Trader Rating: 14 (100%+)
I might get killed for this, but here it is. Debating about going from 2016 to 2019, just not sure it is worth it, your thoughts? I have 2 T4 2016 and run 21.5 and 17.5. Feeling the need for a change.
Iketruman is offline
Old 02-18-2019, 11:34 AM
  #321
Dan
Dan's Avatar
Trader Rating: 76 (100%+)
Probably worth it if you are racing on carpet and your existing car has seen heavy use. Nothing like starting out with a fresh new build after a few years. If it is on asphalt and your '16 is very low mileage, maybe just keep it a little longer until the '20 comes out in 7-8 months.
Dan is offline
Old 02-18-2019, 11:55 AM
  #322
Iketruman's Avatar
Dan, thank you. I am one of those guys that has a ton of spare parts and just changed out both chassis. I run on asphalt in south Florida and still like both cars. Thanks again.
Old 02-18-2019, 12:25 PM
  #323
Suspended
what setup are you running? What tires, and how tall is your glue? We typically run between 58-59mm of glue on the fronts.
R Dodge is offline
Old 02-19-2019, 08:15 AM
  #324
i have max's setup from 2018 mhic i glue the tires at 59mm.
SGrubb is offline
Old 02-19-2019, 08:49 AM
  #325
Suspended
I searched the xray forum but couldn't find it. Could you provide a link to it?
R Dodge is offline
Old 02-20-2019, 10:11 AM
  #326
RC MARKET's Avatar
RC MISSION New spare parts for T4
RC MARKET is offline
Old 02-20-2019, 10:15 AM
  #327
RC MARKET's Avatar
XRAY after release New Pure Tungsten Chassis Weight 13g (2)
& Pure Tungsten Center Chassis Weight 30g
Old 02-20-2019, 12:04 PM
  #328
JoeyE's Avatar
Trader Rating: 45 (100%+)
Originally Posted by JEFFs SC10
anyone looking to sell a 19? lmk!
If you are set on $800 plus shipping, I will sell you mine. All original plus aluminum chassis, aluminum arms, Bruno servo, brass suspension holders, etc....too much to list. Only raced the car two times, no crashes. Now it sits and collecting dust under my coffee table.
Need money to buy another Light Saber
Ggrant likes this.
JoeyE is offline
Old 02-21-2019, 07:59 AM
  #329
to R. Dodge i got the setup on petitrc i check to see if i had the right one but i cant find it. but i have a copy at home. the car has no traction roll like symptoms. just in the sweeper the two inside tires come off the carpet. and the car push's .
SGrubb is offline
Old 02-21-2019, 08:00 AM
  #330
Dan
Dan's Avatar
Zero Tribe working on T4 mid motor conversion - Red RC - RC Car News
Interesting...
Dan is offline
