T.O.P. Racing "Scythe" 1/10 EP Touring Car
#1306
If so whats the largest spurs that fits??? With the largest spur fitted, whats the largest 48pitch pinion gear that can fit??? Care to test them for me???
#1307
The slots are quite long on the TOP, I have fitted 32 pinions to a 78 spur and still had plenty of room.
#1308
Trader Rating: 171 (100%+)
E.J I was told to get a roll out of 50/51 on the 17.5 and 40/41 on the 13.5 I might be off on this I don't have the paper in front of me..
#1310
Ok So if I have to go up on the pin. how many should I go up? Do I go from 44 to 50 or 44-47. I don't want to melt my speedo Brushless is all new to me..
#1311
btw george im not sure when you are going to be at 360 but i can help you if you need it.. i usually sit near Mike H at the track..
#1312
Joey I'm going to try and make it down for this Sat. I hope I'm waiting on some parts. Also I don't have my GFX yet sent it out for up grade should have it back next week. I'll look for you on Sat. if everything is ok thanks Sal is going to charge my pack for me
#1314
Mario cars go together very well. Mario when you install your shocks on the top of the tower make sure you don't over tighting the nut That hold the top of the shock on. you will see what I'm talking about.Other than that my TOP TC is ready for this Sat. Good luck
#1315
George, let us know how your first run goes.
#1316
Cool guys...Thanks.So far so good.Very pleasurable build.Can't wait till sunday!Anybody have any thoughts on a body?Will be starting on low bite CRC ozite.We will be the first to run roadcourse since last springHave an RP-9F so far.Was thinking of a Parma Alpha also,as it seems to me to be a pretty neutral body.Mario.
#1317
Hey, lotus1, same here, but i´m build the ARP version, the new manual are very clear, with photos not drawings.
This weekend, go to test the car, too, i have Scythe red version, for me the best body are Mazda speed, in asphalt.
Greetings, Luis C.
Greetings, Luis C.
#1318
Greetings.Asphalt season just finished here.Used the mazda on my Cyclone.Yes,works great.Moving in to the carpet.I used the Mazda and Stratus last year...depending on temp and traction.The build is almost done.Got most ptut together..going thru all and fine tuning fittings etc.Very nice.Will post sunday nite after first running/tuning.Talk soon,Mario.
#1320
