Robitronic Avid Touring Car
#316
Yep,
I don't think the next version will be a specific carpet chassis as it still comes with a 2.5mm thick main lower chassis and 2mm upper deck. It's quite thin for carpet use only.
That's correct, the chassis doesn't have a symetrical flex from the start which can create strange reactions sometimes. And after a very slight crash only (a bit tough on an apex) then the chassis gets tweak and the car want to push on a side when on-power. Really boring...
For asphalt racing (it's also valid for any surface actually), if you set the car right on the setting blocks and tighten (approaching first) all the upper deck screws with the right symetrical pattern (then final tight but not overtight), things should be just fine.
Between two runs, don't hesitate to untighten a bit the upper deck screws with the car back on the setting blocks. It will release the inner chassis stress. Then tighten the screws again with always the same pattern.
This method is valid for any car so don't worry too much about the new version. It will work good, i'm convinced.
I guess this Flex default should be reduced on the new version. I heard that the prototype cars were working pretty well on both carpet and asphalt. Let's wait and see !
Cheers
Slide
Cheers
Slide
#317
Hi there,
If you have the sliver dogbones, yes, they are not hard enough.
Robitronic released the black ones, same part number.
At that time (at least, it was like this in France), Robitronic replaced them free of charge. Check out with your usual dealer.
The red anodisation will be kept for the Avid'09. Release date would arrived in the very middle of the year. Patience, it will not be long ;-)
Cheers
Slide
Cheers
Slide
The part number is RA 0203
I have tried the impoter here in Australia and has none he said that there has not been an issue with them as for free of charge he said he knows nothing of it and the time difference over here and my job means conficts with the US. But will track them down from Europe or Japan.
Steven
PS has any one tried Xray dogbones ???????
#320
Slide
Steven
Steven
good shake down, a bit disappointed in some of the car due to the softness of some of the parts BUT that aside finally got to a setup that was quite good for the weekend the car was hooked in the finals but the driver wasn't yes thats right i am only an average driver but lover this car, it has a heap of potential.
Using SMC 4000 and SMC 5200 (fits perfect) just had to use tape instead of the battery strap.
I did bend 1 of the hard dogbones but it was a high speed incident.
Has anyone used Jaco Rubberz ???? i found them quite good.
Run 35w oil and Blue springs all round great turn in and stability.
Steven
#321
#322
Does anyone know when there will be pics of the new avid. Also is the 09 avid going to have a one way or is it going to be switched with a differential to handle better on carpet. Guys also what gearing should i use on it running a 17.5 brushless (have not read much on how to gear sedans). Thanks cant wait to see the new avid release hopefully we will see it at some big events
#327
Does anyone knows how many teeth are in the Avid's rear belt?
#328
#330
You can find some pictures of the very latest version of the new AVID.
Comments in english too.
http://www.petitrc.com/_forumphp/showthread.php?t=45305
Still no excat date of release...
Slide
