Tekno RC EB48.4 Thread >
Like Tree311Likes
    Hide Wikipost
Old 01-11-2018, 05:44 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno RC EB48.4 Thread
Last edit by: billdelong
Welcome to the EB4.4 Wiki page.
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top.
Bob B 8/10/17 - Should I start with the kit setup?
The kit setup is a great place to start. One other option that many of us start with is Joe's rough track setup. You can find that setup here
In order to run it you need 3x2.1 pistons and 3x2.0 pistons. (They are marked on the sheet as 3.1 and 3.0).
Matt W 7/7/17 - What is overdrive and when should I use it?
The NB48.4 comes stock with a 12t pinion (TKR8152) and the 39t ring (TKR8151) in both the front and rear and the EB48.4 has a 12t pinion (TKR8152B) and the 40t ring (TKR8151B) in both the front and rear.
The two sets of gears are used to overdrive the front of the EBs or underdrive the rear of the NBs. If you have both vehicles and want to try underdrive it's as easy as swapping the front diff and pinion of the EB and the rear diff and pinion of the NB. Underdrive helps on very loose tracks, when you need more on power steering or if the rear of the car feels loose.
Tips and Tricks
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Old 08-20-2019, 04:37 PM
  #1696
I really hope they make the car wider like losi did with losi 8xe and like hb 819e that would be awesome too see that happens
ExRCRacer likes this.
MadMick is offline
Old 09-01-2019, 12:01 AM
  #1697
They definetly are. There have already been pictures of Joe's and Jared's ebuggy's showing them to be alot wider. Seems like it will be around the width of the HB or losi.
codysb05 is offline
Old 09-01-2019, 03:17 AM
  #1698
How do you know that do you have photos off it and all
MadMick is offline
Old 09-01-2019, 03:48 AM
  #1699
This is jared wiggins car. It is wider that the current eb.4
Skaar_rc is offline
Old 09-01-2019, 05:22 AM
  #1700
Oh I saw that but it look the same from the side look
MadMick is offline
Old 09-01-2019, 06:00 PM
  #1701
One thing for sure is the new car will have a new diff. It got 4 bearing if i'm not wrong. U can see the blueprint at the tekno latest t-shirt
Skaar_rc is offline
Old 09-02-2019, 12:37 AM
  #1702
Does anyone make CF Shock Towers for the EB48.4
Malazan is offline
Old 09-02-2019, 03:49 AM
  #1703
Most famous is Dutch Oven Design. Before this they sell the alu DoD rear shock tower with extra holes for camber link. Now they stop making alu tower and starts with cf tower... But only for rear
Ones that makes both front and rear are
1. Prostar rc
2. Beserk rc (aus)
Both made some customization on their cf tower.
Especially beserk rc. But u cant find in their website, u need to email them for it
Skaar_rc is offline
Old 09-04-2019, 10:17 PM
  #1704
I ordered the Pro Star set,
thank you
Malazan is offline
Old 10-08-2019, 09:13 AM
  #1705
boudin4evr's Avatar
Trader Rating: 18 (100%+)
It is also the same shock bodies Front and Rear, lower center of gravity, ball bearing sway bars, and yes diffs are bigger and hold 35% more oil and are consistent throughout the whole run and with bearings on out-drives, they run much cooler and do not burn oil up as fast!
boudin4evr is offline
Old 11-14-2019, 06:53 AM
  #1706
hookedup's Avatar
Hey guys, newb question here. I’m looking at getting a buggy and the 48.4 has caught my eye. Is there a reason that Tekno uses such a narrow chassis? Does it improve handling characteristics? I’m also looking into Losi and associated 1/8th scales. Totally new at this so any input would help. I’m running at a local track and I’d like a nimble buggy..
hookedup is offline
Old 11-14-2019, 01:52 PM
  #1707
hookedup's Avatar
Originally Posted by 1/8 IC Fan
Why, It has a great layout as is. I think its a hallmark of Tekno, nice and narrow. No complaints here, from any of my EB48 buggies or truggies. The only thing that perhaps the narrow cars can not take advantage of, is the newer aero bodies of the wider cars.
so there is no performance loss for a narrow chassis?? Or is it an advantage? Just wondering.. I’m about to buy a 48.4
hookedup is offline
Old 11-16-2019, 07:01 AM
  #1708
No performance loss, but since it is crampt, u are limited on what electronics u can use.
The buggy is nimble, aggressive and lightweight, but it does get up set easily when clashing with other buggy. So it will teach u how to be a good driver around traffic.
If u want to upgrade, first upgrade wud be alu servo horn. At advance level, u can upgrade ur shock package to wiggins' piston setup
hookedup likes this.
Skaar_rc is offline
Old 11-17-2019, 08:22 PM
  #1709
mebolson's Avatar
Trader Rating: 41 (100%+)
Trying to wait patiently...
mebolson is offline
Old 11-17-2019, 09:31 PM
  #1710
When’s the new version supposed to be out ?
weedsnager is offline
