XX-4 Forum
#2311
p.s. Dyno Dan, My friend Matty Primmer (Aus driver from the Worlds in Finland) reckons you are the master at keeping a secret. I suppose it's pointless to ask if any new Losi 4WD will be an evolution of the XX-4 then. I'll ask anyway though, will the new car take its inspiration from the XX-4? I remember the original prototype had a metal chassis, so that might suit your design philosophy.
#2313
cheers guys , yes on the clicker under brakes . i also had some clicking in some turning instances . i was listening real carefully and the car has alot of noises , all good .
#2314
XX4 Swaybar
Where are people purchasing their swaybars from?
Were they a standard item on Worlds Edition car's... I have had a look on Amain for a XX4we sway bar kit and have not come across one.... Any help would be appreciated!
#2316
AE
Radio Active: I can keep my cards pretty close to my chest I think the XX4 is an amazing platform that so many other companies used for inspiration, but missed the mark. I love seeing all walks of people dig out there old battle axes (XX4s) and share the same amazement at how good the car was, and how much better it is with brushless and lipo. Only time will tell what will come to fruition, but the XX4 is inspiring to say the least
Brent J: Most people have found a piece of .050" music wire, and custom bent it to work w the losi sway bar ball ends. The swaybar wasn't standard in the kit.
#2317
Dan. thanks for the info. I need to change a few things up. I will be running my worlds on new years eve at trackside. I appreciate the info.
#2318
#2319
#2320
.055" swaybar mounted further out on the arm (1.32" from inner hinge pin to stud hole)
if you choose to use the stock bar stud hole on the arm use something like a .077" size bar but it will want to pop out of the clips often and has a later engagement moment
heres a link to a pic. http://www.oople.com/forums/attachme...4&d=1195098727
hope this helps
#2321
Awesome Gopes that the xx4 showed up mate. Mine finally showed as well. We"ll have to hook up for some runs at chargers in the new year.
#2322
xx4 info links
Here are a couple of links for the xx4/4WE manuals, setups sheets, addendums etc.. For the Noob's & Revitalized Veterans
Oople Build Review of xx4WE
http://www.oople.com/rc/photos/reviewxx4/
PetitRC xx4WE Manual/Addendum/Setup Page
http://www.petitrc.com/setup/losi/Se...oubleX4WE.html
Shocktower Braces: I use these, and I used thin CA to glue the rear brace pieces to the tower. My car has had some massive wrecks & been run over by SC4wd's a few times too, and I still have not broken either tower since I added braces.. I think Ellis sells braces too..
http://penguinrc.com/products/losi.html#xx
its a revolution, hahahaha!
#2323
Hey guys. I just ordered the penguin braces to. I already broke a rear tower on not such a bad landing. SO i hope the braces will help. But the 22 armson the front have made the front end bullet proof. And i am not using a pin brace up front.
#2324
I used the pinguinrc carbon brace, they give a support to XX4 towers for sure, suggested.
I always believe in the XX4 platform, I was lucky to found one kit new in a box a couple of years ago in NY. Amazing car.
Driving the XX4 with belts and front motor, this car is on top of its game.
I've got a question, some people put a diagonal cut in the main belt cover across where the rear layshaft is. This enables to access the centre belt and spur gear more easily.
Any difference between this top deck changes and the normal one please?
Here attached my XX4:
#2325
Hey, i have heard people doing this to make it easier to do belt service or pulleys, however it makes the chassis flex more. I have thought about doing this but not sure what i will lose by doing so.
