XX-4 Forum
#3061
Just wondering what sort of weight you guy's are running the car with Lipo's? I have a lead underneath my lipos and the car is only just at minimum weight.
#3064
Guess i will have to put mine on the scales . plan on racing xx4 at qld titles
#3067
It would be good to see u come up for the event . Hopefully Qld turns on the sunshine .
#3069
I'll most likely run mod . I'm fairly new to xx4 and have had a bad run with reliability , belt issues has been the big one . Have recently rebuilt and got some practice in at the the new titles track , and glad to report i actually ran a few packs without anything going wrong . hope to get some more track time this weekend and work on setup and try get this thing dialled in .
#3071
Not tried yet, but I'm waiting to receive some....
#3072
Belt
I just did, Like Beau S entionned earlier, it lasted about 2 full days and start to skip. Once it started skipping, I went to to tighter setting A block with the arrow going pointing to the back but it was still skipping.
I dont have the rollers that goes against the belt though so I would suggest using it.
The front seems to be lasting longer but it as way less load.
#3073
Hi guys can someone give me a starting point for 17.5 in my XX4 as the last time I used this awsome car was with a 9x2 brused motor.
Hope to set this up for my son until he learns to drive a bit better.
Macca
Macca
#3074
Assuming non-boosted operation I'm running as low as 4.9, but my drive train is significantly lightened. Try starting around 5.5, run a heat sink and a fan if you can and check the motor temp every couple of minutes first time out in case I've underestimated the influence of all that steel.
#3075
Hmmmn! i dont have such issue with the rear belt i have this red instead of the typical green losi belts, my concern are the two front side belts its deteriorated already with apparent teeth though!
its obvious that my belts breaks bacause of its age (long time storage) and not by the use.
