TLR 22 3.0 Race Kit Thread!
#4172
If your running the 67mm drive shafts, do you still add the axel spacer. If so, what's the effect.
#4174
#4175
my 2 lads run the olders 22 cars, so rather than buy a load of new wheels just for my 22 3.0, is there a way to convert it back to the older front hub types, if so, what parts would i need?
#4176
#4177
#4180
Finally got around to uploading pictures from my 22 3.0 SR kit. Love the way the car turned out. Props to TLR for making another amazing buggy. Drove it on the track yesterday with the OTB set-up and it was a great performer already. Can't wait to start racing this beauty. Cheers.
#4182
I'm going to order this car in March I just hope their isn't a 4.0 on the horizon.
I believe the 3.0 just came out so I hope it isn't replaced anytime soon.
#4183
Don't worry. Even if a new car did get released. Which I highly doubt it will for some time. This car is such a huge jump in performance over the 2.0.
#4184
Couple questions.
Why is the Direct Drive System (DDS) only supposed to be used on 17.5 motors?
*Note – Use only for 17.5T Spec Motors. This is not designed to work with 13.5T or modified motors
In the manual is states that the 13.5 motor should have a gearing of 70/25, but there is no 70T Spur for the Heavy Duty Slipper (HDS) or 3.0 DDS?
I found this part number [ TLR3978 ] for a 70T DDS but that is for the 2.0 and doesn't fit the 3.0 DDS.
Seems I'm either missing something or there is a discrepancy.
#4185
Couple questions.
https://www.amainhobbies.com/team-lo...63883?v=216080
https://www.amainhobbies.com/losi-sl...-compatibility
I'm not sure if that is for one pad, or if there are two in the package. Seems pricy for just one.
