TLR 22 3.0 Race Kit Thread!
#4321
Is this something so easy I am just missing it?
Couple of quick questions. The setup sheet says Ackermann ball stud low mount or standard. I have the tlr aluminum steering rack. Ackermann spacers would be behind the inner tie-rod ball? Lastly bump steer spacers would be under the outer tie-rod ball stud? Thanks in advance
#4323
thank you. Thought I was right but not sure
#4324
Instead, clean with WD-40. Spray some on a 1" paint brush from the hardware store and wipe your buggy down. It literally paints the dirt away! Let air dry or wipe off with paper towel.
#4325
Happy to report that the CF rear brace works just fine with the exotek laydown! You do have to dremel off the bottom holes and widen the opening, but it wasn't hard. It's not perfect, but really happy with how mine turned out. The one negative is the spur cover will not fit without hitting the shock spring, so that is a bummer. Other than that, looks great. Can't wait to try it at the track.
I'm wanting to do the laydown even though there might be a 4.0 coming out! And getting the TLR laydown is good luck right now.
Thank you
#4328
These are small pics. I can email someone if they want bigger ones. It's not perfect, but not too bad.
The two screws are supported by a kyosho shock bushing/standoff and a .5mm (I believe) washer. It's hard to see in the middle pic, but a little easier to see in higher-res.
#4331
Hopefully just racers jumping ship and going to a different brand. We had 4 racers at my track jump and went to xray, kyosho, and tekno. Now they are "factory sponsored". My 3.0 still killing it.
#4332
Sorry if this question has been beat to death but I need your help.
I just built my son his 22 3.0 and we are running a 13.5T. Our track is OCRC.
What Spur/Pinion are you guys running for 13.5? I appreciate any help.
Thanks!
Thanks!
#4334
Anyone having an issue with tight fitting Shortys? I have a 3.0 SR and my current shorty packs have to be wedged in extremely tight to fit. Just a 4300 mAh Lipo Factory/Trinity battery.
Sorry I am too new to post a link. They sell these at Amain etc.
