Team Associated's new RC8B3e
#1442
#1443
#1445
Well, I was somewhat desperate and picked up a set of Mugen arms,,, looks they can be made to work with a couple easy mods.
1 you need to dremal the area for the droop to clear the chassis a little
2 you need to drill out the hole for the pillow ball stud a little deeper
3- you'll need a couple screws to hole the shocks
Otherwise it seems the geometry is close enough,, with lower ball stud screwed all the way in it has about a degree less camber,, so I just need to screw those out to set the camber,, then set the toe
Edit,, actually broke out the calipers this morning,, the length of the arms from the hinge pin to the end where the pillow ball stud is is identical, and the castor looks to be the same also
#1446
Question - I found an aluminum steering bellcrank set on Ebay. What are your opinions of upgrading the existing plastic steering bellcrank to an aluminum one? Are there any cons to replacing plastic parts with aluminum ones?
Link to the aluminum bellcrank:
https://www.ebay.com/itm/Alloy-Steer...-/191641061371
Looking forward to hearing your thoughts!
#1447
If I bought that kit from eBay, I'd avoid using the steering rack since it's just 6061 aluminum and keep the plastic half of the servo saver that connects to the steering rack. Basically I'd only use half of it.
#1448
I wouldn't install the entire kit. Aluminum on aluminum in the servo saver is going to wear quickly and then won't properly center. You'll be fighting the trim on your radio all the time to get it to track straight after a while.
Any other thoughts on this?
#1449
Hey, anybody having issues with the 3.1 spur gear breaking teeth off. I have had 2 break teeth off and I am wondering if anybody else has seen this issue. The motor has not moved and my mesh is always good and a little on the looser side than tighter side. Never had a problem with the 3e. Looks like the plastic is slightly different on the 3.1 spur gear than the 3. Dont think i got any rocks or debris in the spur or pinion, but it is a possibility. Will the 3 spur gear fit the 3.1 HTC diffs? Whats everybody running in their HTC diffs for fluid 7-7-4? Thanks guys.
#1450
#1452
My point is: Faster motors are only faster if you can drive them faster. Obviously, a lot of people (amateur racers) don't feel the need for more power than a 1900kv can provide. I personally run a 2000kv, simply because the motor brand I run doesn't offer a 1900kv, otherwise I would probably run that.
#1454
It's not necessarily faster cause gearing has a lot to do with that. Higher kv motors tend to need to be geared lower than lower kv motors. It's power going to the wheels and you will have plenty of that with a 1900kv. It's about putting the power to the ground not wheel spin.
