Hot Bodies D216 1/10 2WD Buggy!
#1111
Tech Legend
I ran my D216 for the first time at an indoor clay track yesterday and wasn't too impressed. If I wasn't super gentle on the throttle, the car would spin out. Yes, I was using the right tires for the track according to the experts: JConcepts Dirt Webs in gold (I tried black, too). HW EZrun 60A ESC with the punch level set to 4 out of 9. I'll admit that I'm a complete newb when it comes to tuning so maybe I'm missing something. Setup is stock according to the instructions. Seemed like the problem got worse when I switched from a 175 gram battery to a 235 gram battery (both in the longitudinal orientation). Also, I didn't have any big crashes but still managed to break a rear rod end. Hoping I can get this thing to run as well as my RB5 .
#1113
Are you running on High grip clay ? If so i can see why it wasn't good you need to limit the droop on the shock rod ends.
#1115
Oh ok yea that sounds like higher grip . Yes the shock shafts have lines on them to limit the droop I did the samething on my D413 up to the first line or a little less. Inless the track is blown out or pretty big jumps you can take some out.
#1116
Tech Legend
Trader Rating: 51 (100%+)
Where your tires brand new? If so a lot of time my JC Golds take 5 to 10 runs to even start working at my home track and that includes using a really aggressive tire compound every run to help break them in. On clay high bite no way should a D216 be loose. I ran 2 .5 degrees of rear toe in on the loosest track where guys ran 3 or more and I still had traction. Something just isn't right.
#1117
On my 216, I have pretty much box stock setup except for the following and am having great results on high grip clay.
Blue front springs, yellow rears
shock eyelets up to second line on shaft
1.4 sway bar
21mm ride height front and rear
2.5mm of spacers on the rear screw of arms for more rear toe in. no spacers on front screw. Not sure on the degree toe in for rear.
slight toe out up front
square pack lipo conversion 3d printed a bracket to keep battery from sliding backwards and modified the shorty lipo battery bracket. Maybe the extra weight of the battery helps keep it planted? I feel like adding weights would achieve same results.
Tires are Micron rears and scrubs fronts both clay compound
I did do some exotek upgrads like the top flite shaft, idler, and top gear. Those shouldn't affect grip really though. I have my expo set at 25% on my spektrum radio which gives me softer smoother trigger feel. Might help with spinning out too.
I've also heard that the exotek carbon stiffening plates help tremendously with corner speed. With mine running how it does right now, it's not necessary to spend the extra 45 bucks IMO.
1.4 sway bar
#1118
Here's some pics of the battery mount
#1119
Why is the carbon fiber chassis preferable on low bite surfaces? Every manufacturer uses aluminum and just curious why HB chose CF?
#1120
#1121
#1122
Tech Legend
I bet this was the problem - my tires were brand new. And the car had so little traction that it's hard to imagine any change to the setup making a significant difference. When you say it takes 5 to 10 runs, about how long in minutes/hours of track time are we talking?
#1124
I have yet to try the aluminum chassis out on mine yet. I ordered one so I can see the difference in how the car handles. I'm sure the aluminum chassis will feel more planted and consistent. Only downside is the added weight. Maybe thats the other reason they went with CF. Less weight.
#1125
Thanks! Yeah it would be cool if HB made a hold down plate that would fit the square packs since there's plenty of space for one.
This bracket has held up flawless so far. Been to a few races with it so far.
PM me if you want one made up. I can give you the rundown of what needs to be done to make it work as well. Pretty simple.
