Hot Bodies D216 1/10 2WD Buggy!
#1021
Tech Legend
Trader Rating: 51 (100%+)
Part of why 1/8th is so popular as you can run the same rims on any brand. If 1/8th car companies can figure it out why can't the same 1/10th companies figure it out.
#1022
EDIT: wrong thread.
#1023
Well I thought I finished my D216. I kinda wish I had researched slipper options before buying, because no matter what I do it slips. Tightened all the way, loosen 6 turns & wow that thing slips the moment I squeeze the throttle - in fact it doesn’t really drive anywhere over about 25-30% throttle.
My SC5M works fine with its included VTS slipper.
My T5M has an Avid Evo Triad installed & that’s easily my favorite.
So I’ve some understanding of these things & have built them successfully before. I’m running an SMC 8.5 turn mod motor. Like I said, this thing slips no matter what. I’ve tightened it down to the point where the spring is compressed all the way & it still slips. My thought is that these pads are too smooth.
If you’re wondering, I have taken it apart to ensure each piece is right where it should be & still have no luck. Was going to spend half the day practicing but clearly that isn’t in the cards this week.
Weirdo proprietary system for what practical reason? I prefer Avid but y’all seem to be driving these buggies so I know there is a way. Definitely not driving 40 miles to the track and asking them for help with a buggy I bought online.
Any advice or ideas would be appreciated.
#1024
Sounds like it's assembled incorrectly. I'd take it apart and double check the manual upon reassembly. I recall reading something about others having the same problem and it was due to something being installed backwards. Sorry for the vague reply, but thought it may help. Possibly it's the small black machined collars that go in the ends of the spring. The shallow side goes into the spring and the deep side faces out. Opposite of what you may expect.
#1025
That’s it 100% - thank you, I probably would have had it apart 3 more times before checking those little washers that encapsulate the spring. My brain insisted the diagram had the deeper side facing into the spring. All seems good with the buggy; got extra drivetrain & steering parts as those are what I usually break first.
Now I can definitely hit MHOR RC today!
#1026
#1027
I have been assembling mine and I am not thrilled with the instruction manual. The pictures do not always clearly show the orientation of some of the parts. I just did the slipper assembly last night and now it appears I will have to redo it. It looked to me like the collars both face the same direction, i.e. the side on the gearbox had the shallow end in the spring and the side with the bolt had the deeper end in the spring. So it should be the shallow end of the collar that mates with the spring?
#1028
#1030
#1032
i heard once these cars have a very weak gear. Idler? can anyone confirm or deny this?
#1033
Not necessarily weak. Just seems to wear faster than most. Try and keep a few as spares if you can
#1034
The idler is fine. Just put some grease on it. A very thin film of ep graphite grease is on all of mine and I have no issues with stock and aftermarket idlers.
#1035
The xray is a tad more predictable with the alum chassis. The d216 flexes more and is a little less predictable.
The d216 shocks are the best in the business. The xray are nice but no comparo.
