Tekno RC SCT410.3 Thread
#6076
Looking for spring recommendations for my SCT 410.3. Outdoor loamy dirt 1/8 scale track. The course will be set up as shown below. I am running an xr8 sct and a 5300kv motor if that helps weight wise. The previous guy who had it had this thing set up with Orange LF springs front and rear with 65wt oil in the front and 45wt oil in the rear, but he was racing indoor blue groove clay.
I tend to use losi oil and have always really liked their 35wt (420cst) for front and rear shocks on older eb48sl, but that was when the track was set up for bigger jumps and I also was running stiffer springs. This track is a bit more technical than in my past. Assume that I am using stock pistons.
#6079
Well, they already have a new 4WD SCT model: Tekno SCT410SL - and I have some doubt whether they will keep producing two different kits for one class... They might, but I wouldn't bet the ranch on it.
#6080
Spoke to someone at Tekno as I was trying to Track down a few kits for local drivers.
They told me the SCT410SL isn't a replacement for the SCT410.3, it's design lends itself to Indoor Clay Tracks and such and not as durable (Hell I have a Prostar SCT2410T which is a converted 410.2ET, a side by side manual comparison...I buy literally 5 parts and I have a SCT410SL, they share I would say 85% of their parts).
The 410.3 is for large outdoor Tracks and thus built more durable. The 410.3 is discontinued but a Replacement is on it's way, but no ETA at this time, he wouldn't go into more details, just...soon.
I suspect it is a slightly converted EB48 2.1...maybe different Hubs so a 12mm SCT wheel will mount up, and a few other bits...I had a EB48 2.0, it was a good Chassis, just a Little more Fiddly when compared to the old EB48.2 to EB48.4 and 48SL and SCT410.3.
Tekno has a good business model, build Chassis that share a lot of parts, keeps R&D costs low, manufacturing costs low, and for a Driver, ease of maintenance and parts supply...Just wish they would Expand and make a 2wd Buggy and 2wd SCT
#6082
#6083
#6085
#6086
#6087
Truck sold. Only the upgrade parts are for sale now.
Tekno SCT 410.3 new in box plus upgrade parts
#6088
I just picked up the SCT410.3 and looking for setup tips. We run on an asphalt parking lot with plywood jumps. Layout changes every week, some really tight, some ovals with jumps or even speed paperclip layout with jumps. My son and I run SCTE's and have won the championships the last few years (Mine SCTE with MIP conversion and his is the SCTE 3.0) they work great but I wanted to try Tekno this year (had issues with getting parts between race dates.) The tires that work the best on the surface are the Duratrax Shootouts or the Proline Badlands, I've tried Bandito Speed Treads and they are too loose. Any of the soft compound dirt tires work but wear to bald in only a few races. The Shootouts and Badlands last the entire season.
I've looked around and the setups I've found are all dirt or clay. I was thinking maybe a smooth clay hardpack setup might be close enough. But if anyone knows of a more accurate setup that would be great. I have no idea what setup was on it but they guy I bought it from ran on a red clay outdoor track so might not need much tweaking.
#6089
Got some JConcepts Hazards +3 wheels the other day, and it's a go... the wheel rubbing is gone. I didn't even have full steering throw in the left picture. Keep in mind this rubbing is at full droop. Sure, the "0" offset wheels might be okay in most situations, but I know I'll be asking the SCT410.3 for everything she's got (full droop) in order to tackle the rough terrain outback here in central PA.
#6090
Thank you for posting. Based on the following post from the Tekno forum, what is the inner hinge pin spacing between the front arms of the SCT410.3 and the new SCT410 2.0?
https://www.teknoforums.com/threads/...77/#post-25831
219Likes
