LOSI XTE Pinion/Spur combo question
Looking for some advice. Setting up XTE for general running and small track. XTE comes with 48T spur gear. Losi manual says 16,17 or 18 tooth pinion. Seems a little high to me.
Running a Hobbywing 4274 2250KV motor. Apparently a 15 tooth pinion does not mesh well with the 48T spur. I have seen some switch the spur to a 50T and run a 15T pinion.
My question is do you think a 13T pinion would work well with the 48T spur gear? or should I just go with a 16 as per LOSI manual. I want low end torque not top end speed as I will be running at a small track. Any suggestions would be helpful. Appreciated.
