Tekno RC SCT410.3 Thread
#5821
Joe, I haven't lost any screws. Maybe I've been lucky.
#5822
#5823
#5825
EB48.4 Hinge Pin Blocks
So I’ve got an EB48.4 as a spare and have the stock alloy ABC and D blocks. The A block is part number tkr8161.
The V2 A block that is listed to fit both the EB48 and the SCT410.3 is part number tkr5161.
Has anyone fitted the EB48.4 blocks on the SCT410.3? I see one is for a socket head and the other is for a tapered head. Are they’re any other significant differences? I’m asking because I don’t want to spend another $100 on these if I don’t need to.
#5826
I built my sct410.3 this past week which is my first RC car/truck. Today I got it out on the track and had a blast. Towards the end of the day though one of my 5x4mm set screws came out which turned my 4wd into a 2wd.
one of the fellow racers had a small box of Tekno RC Screwz and in that set he had the right set screw BUT it's a tad too long unlike the original.
I'm home now and I was researching these RC Screwz sets and it states that they have every replacement screw in the kit, but I'm not so sure now because the guy who helped me couldn't find a shorter set screw in the set.
Do any of you have this RC Screwz set? Can you verify if they have the shorter 5x4mm set screw? I would like to order myself a set but not if these sets don't have the same size screws as the original tekno screws.
thanks for any info.
#5827
TKR1603? Always use blue locktite on metal to metal fasteners.
https://www.amainhobbies.com/tekno-rc-5x4mm-set-screw-10-tkr1603/p231871
#5828
Just did this mod to mine and my sons Tekno's, I also added some velcro (the soft side) to the flat surface area. Hoping this helps improve the life of bodies, my 8 yr old son has a knack for destroying bodies faster than I can keep up with shoe goo & zip tie repairs.
I did notice that the body seems more secure with the plastic nuts securing them to the posts than hairpins do, hopefully this works as intended...
#5829
Does anyone know the thread pitch of these Proline M4 x 12mm set screws? I need some longer ones, like 16mm but don't know the pitch. I just ordered some from eBay that were 0.7 pitch. Seems like that's standard coarse pitch for this size screw.
#5830
#5833
Can anyone tell me the differences to spot between a the .3 and .2 models?
#5834
I don't think there was a .2 was there? Anyway here are the updates to the .3
SCT410.3 New Features and Improvements:
Drivetrain Improvements:
- The diffs feature smoother gears and a new 1-piece composite diff cross pin.
- The old steel driveshaft has been replaced with a new tapered aluminum design.
- All of the outdrives and couplers are now lightened.
- Angled rear gearbox with larger bearings is now standard.
- Results – dramatically reduced rotating mass, improved acceleration and efficiency.
- All new front and rear suspension geometry.
- New reduced height front and rear shock towers.
- New V2 hinge pin brace system for incredible adjustability.
- New front arms feature a flat bottom for increased durability and clearance.
- New rear arms feature the flat bottom but are also 4mm longer.
- New rear hubs with reduced offset to match the longer rear arms.
- New longer rear sway bar.
- New clamping spring perches with captured shock boots.
- New droop adjustment screws are now standard.
- Results – lower CG, increased adjustability, increased stability, and increased consistency.
- Lightened black anodized 4mm CNC chassis is now standard.
- Aluminum pivot balls throughout.
- Aluminum suspension and spindle bushings are now standard.
- New lighter camber link rod ends and turnbuckles.
- LCG Lightened Motor mount is now standard.
- M5 stub axles are now standard.
- Split center diff mount makes maintenance a breeze.
- Lightened metal clamping 12mm wheel hexes are now standard.
- Revised front bumper increases ground clearance.
- Larger 6x13x5mm (vs. 6x12x4mm) outer wheel bearings front and rear increases durability.
- Spindles feature adjustable stops for more precise steering control.
- Compatibility with existing parts and options.
- Results – lower CG, improved handling, improved acceleration, and improved durability.
#5835
Whats the best 17mm wheel adapters for this truck, thanks
