Tekno RC SCT410.3 Thread
#391
Hmm, I have some 301 0.050 stainless steel available in 1/2 hard. That would put the perfect weight back there. just a bear to cut and drill though.
#393
That isn't a bad idea from the stand point that the further back you go the less weight you need to get the same effect. Although using the weights allows you to adjust the side to side weight difference. When I was talking about balance that was what I was talking about. The trucks can have a sizable left to right balance difference. Using four scales you can determine where to put the weight.
#394
Anyone know if any of the team tekno drivers are running the rear hubs all the way forward on the new truck?I know some did that on the first truck.
#396
Tech Legend
For you guys who have 4S 1/8 packs how is the fit with SCT410 battery straps? Do you need longer straps, etc?
Sorry I know not really a true "SCT410.3" question but just curious more so to know what to order for the eb48sl.
we need more pics guys and some vids of runs!
#397
Got mine yesterday (thanks Pete) cant wait to get started just have to finish getting the 48 assembled first.
#398
#402
m2c tekno 410.3 replacement chassis
Just got me new 410.3 kit and I am pleased to tell you guys that have already bought my chassis that it is a direct fit to the new .3 model.
the flush mounted steel skid plates are working out really well I am told.
the additional set of battery mount holes is helping a lot with the tuning
of the truck.
chassis weight is about the same as the new kit model
217 grams
#403
TEKNO SCT410.3 ALUMINUM FRONT/REAR BLOCK
M2C Racing is pleased to announce the release of our Aluminum "B"block.
(front/rear block)
part no. m2c 6601
made with 7075 T6 aircraft aluminum and anodized black.
this block is designed to use your existing inserts and is a good replacement for the plastic model.
We also have a kit that replaces the rear plastic hinge pin support blocks
and has the B block included
part no. m2c 6600
#405
Just got mine today. Thanks for all the info you all post
