Tekno RC SCT410.3 Thread
#243
Received mine today oh yeah ...thanks to tekno for always having awesome products will post pics first of week when start build
#244
I have be
ng on the kit, and will update with pictures!
One thing of note: So far the rear camber links, and rod ends are not the same as before. The inner rod end is thinner, and straight. I wouldn't dare thread my Lunsford turnbuckles into it. The Lunsford turnbuckles are 4.75mm ROUGHLY, and the new Tekno stock turnbuckles are 3mm.
I also used the #19 drill bit picked up from ace to drill the arms in the absence of a 4mm reamer, it worked great, and is a cheap option! Also your carbon diff plates are a direct swap.
#246
That new center shafts looks great
#247
I have be
I also used the #19 drill bit picked up from ace to drill the arms in the absence of a 4mm reamer, it worked great, and is a cheap option! Also your carbon diff plates are a direct swap. I'll do a shock build walk through tomorrow, including drilling your own pistons.
#248
Trader Rating: 53 (100%+)
Are the stock turnbuckles the same size as the older truck? I sold my older truck a while back but don't remember them being that skinny.
#249
Thought I read elsewhere that other companies have used composite cross pins in their diffs for a while and haven't seen any issues with them.
#250
Does the mc2 chassis fit the sct410.3?
#251
While they held up well enough I still did not like them. Your diff setup should be from the fluid viscosity not the fitting of the moving parts over time.
#254
I have be
Yes, all of the holes are unchanged. And I believe M2C's chassis has the front bulkhead holes countersunk as well for the short bumper.
Durango truggy I had came with them, I had to sand them down to get the gears to move. They were such a tight fit that the diff was locked.
#255
who has these in stock I'm looking for one asap, money burning a hole in my pocket
